JDM MR Headlights + HID fogs installed.
Old Apr 3, 2005 | 10:39 AM
WarmPepsi's Avatar
Well, hated the look of the stock tails, so i had to upgrade to the JDM tails.
Well, then the didn't match the headlights so i had to swap those too. Used an old 5k HID kit from my rsx, and custom fabbed it into the fog spot.
Old Apr 3, 2005 | 10:41 AM
WarmPepsi's Avatar
more...
Originally Posted by WarmPepsi
here's a semi-aiming guide.
Low Beam - Highest setting.
Low Beams - Middle Setting
Low beams - lowest setting.
Low Beam + 5k fogs - Highest setting.
Low beams + fogs - Middle setting.
Low Beams + fogs - Lowest setting.
Old Apr 3, 2005 | 10:42 AM
xLaNcErEvOx's Avatar
that looks very aggresive... in a good way
forum04pl's Avatar
looks great! i know a kid with a tb evo with hid fogs and it looks sick
Old Apr 3, 2005 | 10:44 AM
soule77's Avatar
Thats nice
Old Apr 3, 2005 | 10:47 AM
SlowRyd's Avatar
Aren't you going to be killing on coming traffic.
looks good, but i feel bad for people driving at you.
Old Apr 3, 2005 | 10:49 AM
WarmPepsi's Avatar
yeah, thats partially the reason i posted this up. I've never seen a pattern on the JDM headlights, i assumed they'd have the minor little angle and back flat up to the right, instead they're up and to the left pretty heavy.
also: the adjusting motors that the usdm has, works for both the high and low beams, whereas it only works for the low beam on the jdm.
Old Apr 3, 2005 | 11:04 AM
evo 8 ya's Avatar
So is that as far right as the JDMs can be adjusted?
Old Apr 3, 2005 | 11:07 AM
WarmPepsi's Avatar
i didn't adjust them at all, and if you did, you'd want to actually adjust them left. see the big white spot on the left, if you can move that farther left, it'd actually be better on oncoming traffic's eyes.
Note: this is with them on the 0 setting (highest), when i turn then down, they get significanly lower, and less blinding, but they will always blind.
edit: tonight i'm gonna go out and lower the drivers side one, and pump the passenger one up.
Old Apr 3, 2005 | 11:11 AM
evo 8 ya's Avatar
OR left depending on the way you look at at. Thanks for the pics.
ex-honda's Avatar
You have to remember to that the picture of the light beam is not that far from the garage door. From far away, it might be blinding to oncoming cars. Also if it's to blinding and a cop is coming at you, he can pull you over and give you a fix it ticket to have your headlights adjusted. Not kidding. A couple of my friends got pulled over when they bought an aftermarket headlights for their Acuras and didn't really care about the light beam and got a fix it ticket.
Old Apr 3, 2005 | 11:12 AM
WarmPepsi's Avatar
ahh, i gotcha,
no prob.
Old Apr 3, 2005 | 11:13 AM
WarmPepsi's Avatar
i have an rsx. Aftermarket hids were in it, blinding glare was all over, lit up EVERYTHING. this is about the same.
Old Apr 3, 2005 | 11:20 AM
WarmPepsi's Avatar
also, if you guys compare the beam from one to the other, you see the drivers side is pointed higher than the stock drivers side, and the passengers side is lower, compared to stock.
lack of sleep put it off for another day
Old Apr 3, 2005 | 11:34 AM
SlowRyd's Avatar
The JDM are for RHD, bc they drive on the other side of the road this isn't a prob for them, but is a common problem with importing these to the US. The Shield inside the projector is backwards(opposite) DOT and you will need to open the projector and flip it or trim it to change the output so it's not blinding oncomers.
JDM = ----\____
DOT = ____/-----
