Subwoofer install question..
Old May 5, 2005 | 08:26 PM
JSYEVO's Avatar
for those of you who installed the sub woofer, did you guys have to drill a hole in the fire wall or is there an existing one on the drivers side? couldnt find one. thanks
Old May 5, 2005 | 08:30 PM
healthynine's Avatar
haven't checked, but in doing installs in plenty of other cars...there has to be a hole you can use without drilling a hole. I guess it doesn't hurt anything, but I just hate the idea of doing it.
Old May 5, 2005 | 08:35 PM
chinto's Avatar
nothing easy on driver side passanger side there is a gromit. on evomoto there is a how to on puttn a hole in the driver / center of the fire wall
tke_413's Avatar
I drilled a new hole on the driver's side above the pedals.
Old May 5, 2005 | 08:42 PM
JSYEVO's Avatar
thanks, ill check up on the how to
Old May 5, 2005 | 08:50 PM
JSYEVO's Avatar
looked on the site, and looked under the boost gauge install and it says to look at "general how-tos" for instructions on how to make the hole, and i look in "general how-tos"....not there?
Old May 6, 2005 | 05:09 AM
jdub24's Avatar
There's a grommet on the passenger side. That made things pretty easy for me.
Old May 6, 2005 | 06:06 AM
smackdaddy's Avatar
you can also feed it into the drivers side front fender (up by the air intake) over top of the fender well and down behind the fuse box there is a grommet to follow into the cab. This is a bigger hole if your looking to run large gauge wire.
Old May 6, 2005 | 06:25 AM
JSYEVO's Avatar
its an 8 gauge, is there a how-to on this? i think im just going to drill but i dont know where. picutres please! and smackdaddy, do you have pics to show how to do this? thanks
Old May 6, 2005 | 06:48 AM
nhsean69's Avatar
I fit a 4 gauge wire with grommet through a drilled hole above the pedals. It was real easy and took about 30 seconds to make the hole. It is sealed tight with the grommet. You can use the hole in the passangers side too. Its behind the glovebox to the upper right. You can see it from under the hood also.
Old May 6, 2005 | 07:01 AM
j-evo8's Avatar
Im running 4ga. through the drivers side grommet near the fender. I used the passenger side grommet for my boost guage install.
Old May 6, 2005 | 07:08 AM
smackdaddy's Avatar
If your running 8 gauge easiest to go through the pass side grommet, but you'll waste some wire. If your looking to end up with it on the drivers side of the car and want the shortest possible route, use the inner fender method. I'm sorry, I do not have any pics of routing the wire, just after install pics none showing where the wore enters the fenderwell. Sorry.
Old May 6, 2005 | 10:51 PM
JSYEVO's Avatar
just drilled a hole, looking from in the hood, its right below where the throttle cable goes through the firewall. thanks for the help~!
