JDM Beatrush UnderPanel - 1st in the U.S.
Old Oct 14, 2005 | 12:42 PM
Ludikraut's Avatar
Originally Posted by Kami Speed
We fitted this on a stock bumper and C-West front bumper and fitment is perfect. Makes the whole bottom part flat, to reduce air turbulance. Plus, it has enough room to fit a bigger intercooler and downpipe; unlike the stock panel which will require triming of the stock plastic. Moreover, their will be no worries about the undertray melting if bigger turbo, etc. is added.
This underpanel can be attached to any stock bumper, since it attaches to the frame of the car. It perfectly attaches to stock bumper & C-West bumper. Another great function of the underpanel is the wheel well extended pieces that increases cooling of the brakes by allowing more air to pass through from the front all the way to the front wheels.
Looks pretty nice, but the pictures still don't show exactly where the panel attaches to the frame. Also, as a sidenote, I'm not sure if the wheel well extended pieces are such a good idea, since they open up a path right into a high pressure zone (front of the tire), which in the case of the passenger side may interfere with airflow over the oilcooler.
l8r)
Old Oct 14, 2005 | 12:47 PM
Kami Speed's Avatar
Thanks alot everyone; here are some more pictures with the stock bumper:
Pic 15
Old Oct 14, 2005 | 12:56 PM
Kami Speed's Avatar
l8r)
Picture 4 shows where it attaches in the center area of the underpanel and on the rear it attaches where the lower tie braces are. As for the side wheel well, its only a small extension for attaching the panel and for air to circulate. Their is not enough surface area within the slits to cause any high pressure to negatively influence the airflow of the oilcooler. .
Old Oct 14, 2005 | 12:59 PM
il2az's Avatar
Wow... Looks nice, and the price isn't too bad either
Old Oct 14, 2005 | 03:49 PM
mdosu's Avatar
do you by any chance sell a rear diffuser?
Old Oct 14, 2005 | 04:05 PM
PurgeIt's Avatar
What are the material specs for that undertray? Thickness?
Old Oct 14, 2005 | 04:09 PM
702RSevo's Avatar
damn that thing is clean
Old Oct 14, 2005 | 05:41 PM
marks03evo's Avatar
damn that looks like a quality piece for sure!
Old Oct 14, 2005 | 06:00 PM
Kami Speed's Avatar
The Beatrush underpanel is made of 2017 aluminum & its 2mm thick. Its thick enough for rally competition and light enough for time attack; as used on these Beatrush vehicles:
https://www.evolutionm.net/forums/sh...d.php?t=162494
As far as a rear diffuser, Beatrush hasn't come out with one yet. However, with enough interest we could have them make one.
Old Oct 14, 2005 | 06:41 PM
scott88vr6's Avatar
I took my plastic one off because it was a pain. Why pay for more headache
Old Oct 14, 2005 | 07:53 PM
Ivan MR's Avatar
What is the purpose of this piece over stock? Just curious. Thanks Ivan
Old Oct 14, 2005 | 08:07 PM
spoolingEVOx's Avatar
i am totally going to jump onto the GB for this piece.
they should work on a true rear diffuser for the IX rear bumper..
Old Oct 14, 2005 | 10:04 PM
PurgeIt's Avatar
Cool... 2000 series alloy should be pretty good. One more question... is it a heat treated alloy?
Old Oct 15, 2005 | 12:56 AM
Kami Speed's Avatar
^Yes, its heat treated.... Thank you for the support spoolingEvox; you will love this product..... The Beatrush Under Panel enhances downside rectification at high speed and generates down force. It also restrain the air stream from getting caught in the engine room to inhibit the engine from over heating.
Old Oct 15, 2005 | 06:48 AM
nothere's Avatar
where do you sign up for the undertray?
