Scuff marks from AutoX cones
Old Jan 20, 2006 | 02:53 AM
sponge bob's Avatar
I have a lot of cone scuff marks I need taken off. They have been on the front bumper for close to a year and wax just ain’t doing the job. Any suggestions? No, it’s not my car I’m working, and yes I have scolded the owner for being stupid.
Old Jan 20, 2006 | 06:11 AM
walkedu's Avatar
Some very high grit sand paper maybe? I used that once to take spray paint off my motorcycle. Then give it a good waxing.
Old Jan 20, 2006 | 06:12 AM
sayanara's Avatar
Sometimes gasoline works. But use sparingly and at your own risk as it could damage the paint and its flammable.
Old Jan 20, 2006 | 06:14 AM
whitet777's Avatar
I've had some success with clay bar removing the deposited rubber. Then Zaino to wax out the slight scratches.
Old Jan 20, 2006 | 07:39 AM
WHTEVO's Avatar
Try some 3m rubbing compund, it should do the job.
Old Jan 20, 2006 | 10:00 AM
TheGVR4kid's Avatar
3M has a special product that's used for taking scuff marks off of boat hulls. You can pick it up at just about any marine products store.
Old Jan 20, 2006 | 10:09 AM
jonpfive's Avatar
In response to post #2, if you sand with 2000 or 2500 grit paper, you WILL have to buff the spot or deal with dull paint. In response to post #3, NEVER use gasoline on paint for anything. I would recommend 3M's Perfect-it 3000 line of products, Extra-cut Compound #06060 will remove the marks, and if you need a little more polishing, I believe the part # for their swirl mark remover is 06063. I work at a body shop and know paint care very well. After the marks are gone, follow up with a coat of your favorite wax. Good luck to ya.
Old Jan 20, 2006 | 10:14 AM
Cajun Power's Avatar
I was able to wax mine off. There is some Meguiare's Scratch X in a tube that worked for me. It is a wax with a minimal amount of compound in it.
Meguiar's SCRATCH X Fine Scratch & Swirl Remover (google it!)
Old Jan 20, 2006 | 11:01 AM
Tarmac02's Avatar
Mr. Clean Magic Eraser,....
laugh like I'm joking,... but you're gonna go home and try it
Old Jan 20, 2006 | 11:19 AM
navypaul's Avatar
i agree with the clay try that 1st then wax it
Old Jan 20, 2006 | 11:20 AM
btuneallen's Avatar
You can use paint thinner.. but very sparingly. I had my car spray painted before, and paint thinner took it right off without damaging the cleart coat.
Old Jan 20, 2006 | 11:25 AM
chrisw's Avatar
Diesel fuel works well, so does WD-40.
I have plenty of scuff marks on my EVO, tell you customer to wear them like a badge of honor
Old Jan 20, 2006 | 12:07 PM
JasonS's Avatar
avoid the cones!!!!!
Old Jan 20, 2006 | 12:11 PM
Nez136's Avatar
i had a bunch of scuffs from a nice drift at AutoX one day, it took a buffer to get the damn things out!
Old Jan 20, 2006 | 12:17 PM
'ringmeister's Avatar
regular liquid wax works well, not even cleaner wax is neccesary.
