-PICS- of my Carbing Under-Panel
Old Mar 8, 2006 | 06:53 PM
Bluetuscani04's Avatar
that ****s nice
Old Mar 8, 2006 | 06:56 PM
GreddyEvo's Avatar
Looks like a great product to me. How much does it weigh? Just curious.
Old Mar 8, 2006 | 07:01 PM
06MREvo's Avatar
subscribed
Old Mar 8, 2006 | 07:02 PM
dnace's Avatar
is that little door thing with four bolts an access to the filter?
superscout03's Avatar
its very light, just a little bit heavier than the stock one, well if you subtract all of the plastic push plugs that the stock one uses it probably weighs the same, Ha ha ha
Old Mar 8, 2006 | 07:10 PM
RedEvoInKy's Avatar
Looks great! I bet Mitsu. will void your warranty for improper airflow underneath the car.....
Old Mar 8, 2006 | 07:41 PM
hondafan's Avatar
i'm about to order one right now cause i had about enough of taking those hated plastic clips out! i heard you have to remove the panel to change oil though. oh well, 6 bolts to change oil is better than 32 clips to tighten IC pipe!
Old Mar 8, 2006 | 07:46 PM
metzpl's Avatar
hahahaha....agreed
Old Mar 8, 2006 | 08:09 PM
hueman's Avatar
Originally Posted by Evo Police
Anyone know if this will fit if your car has a aftermarket front lip such as the Do Luck Carbon?
I'd be surprised if it did not work together, since the do luck has stock mount points on the lip as well, no?
but it'd be great if we got a better picture from underneath, or a picture of the panel laid out with the front distinguished and the mounting points highlighted...
Old Mar 8, 2006 | 09:38 PM
The under panel is not connected to the front lip, its connected to a bracket that comes with the underpanel that mounts to the frame where the intercooler is mounted, I dont see why this would not work with an after market lip. It should work just fine.
Old Mar 8, 2006 | 10:30 PM
eling99's Avatar
superscout told me that this is mounted to the stock front lower arm bar...anyone know if it would work with the croxx plate?
Old Mar 8, 2006 | 10:53 PM
HAMMERS's Avatar
looks nice i wish i had some money right now.
Old Mar 8, 2006 | 11:56 PM
Evasive EVO's Avatar
The weight on the panel is right around 13lbs. A little heavy in my opinion but if you look on the positive side, it creates smoother airflow under the car and acts as a "guard" of sorts against debris flying underneath the car, AND it's a lot easier to take off compared to the stock undertray.
Ed @ Evasive
Old Mar 9, 2006 | 12:20 AM
Danny23's Avatar
what about oil changes, do you have to remove the whole tray or does that plate with the 4 bolts come off for EASY acess to the drain bolt and filter
Old Mar 9, 2006 | 09:58 AM
sirloin1219's Avatar
does this underpanel work with the street concept lips? and do you guys do install as well?
