Zainos gods, i need ya help
Ok i have a 2003 black evo, has been washed and well kept but with normal car cleaning stuff. Now im doing the zanio's i striped it twice with dawn, then did the claybar. Now my issue is that the paint has like these water spots that are like in the paint. NOt like the stuff you just get when the car dries with water on it. I figured the clay would take it out as it pulls the bugs and tar super fast, but im not having any luck. These spots are only on the roof and hood and its all over. I am going to try the Z-PC Fusion Dual Action Paint Cleanser Swirl Remover, but i always thought the claybar was the god for removing stuff like this. Any help is apriciated. thanks guys
I would try the Scratch/Swirl remover and see if that helps. Claybar take off contaminents off the paint but not swirls/scratches/etc.
Good luck!
Will be doing the Zaino day too hopefully next week!
Good luck!
Dunno of this is true but it seems pretty solid...
https://www.evolutionm.net/forums/sh...2&postcount=11
Z-PC will not do too much IMO. You need to grab yourself a Porter Cable, some hard cutting pads, and polishes and compounds to perfect the surface. Zaino wont make your car beautiful...proper PREP will. Find a detialer in your area to do a defect removal with your paint before sealing it.
ok heres an update, when i use a good amount of 3M™ Imperial™ Hand Glaze, 05990,
It takes these water spots of, im gonna try the zanios stuff to to see what helps then its on the the z5, i hope
Lasersleeper
Aug 21, 2007 12:11 AM
