post pics of aftermarket front mounts pllleeeaaassseeee
Old Oct 21, 2006 | 06:10 PM
  #76
WhiteEvo05's Avatar
Originally Posted by x838nwy
The HRS 079 is not listed, but last I checked it was something like 280,000JPY or somthing crazy. iirc, it's the same width as the 073 wide (see pic on the linked page) but with an 079 core. Basically Uber expensive but if you have a big turbo, it's probably the best ic you can get...
Did not know about the HRS version being a "wide" 079...I gues that explains the 250.00USD premium over the regular 079. Might be worth it since I want to go 50trim in the future...although the regular 079 would probably be more than enough FMIC
Old Oct 21, 2006 | 07:30 PM
  #77
x838nwy's Avatar
WhiteEvo05, no worries dude, it's all good fun!!
About the Garage HRS ic, I think it would be better if you check with your supplier. I read about it a while back, but we I remember it's a custom core of some sort. ARC do 100mm thick or 70mm thick also so it might even be a 100mm thick version with the tapered core in which case it would be a 109 rather than 079... which would be pretty aewsome. HRS has apparently no info on it anymore.... strange...
Old Oct 22, 2006 | 08:42 AM
  #78
t51quicksilver's Avatar
Can anyone confirm or deny the rumor that the Perrin FMIC is the same as the original version of the Neisi FMIC? I was really in the market for the Neisi core but since they are no longer available then my search continues. The real reason I ask is because the Neisi core seemed (according to Kevin and his testing) to be the best option in terms of pressure drop off and cooling efficiency also I really like their Piping kit which is still available I believe so I would use their pipe kit and the Perrin FMIC if they are the same and eveything would fit right without having to hack anything up to fit properly. If anyone knows or can confirm this I would love to know...
Thanks,
JOe
Old Oct 22, 2006 | 10:53 AM
  #79
EVOSlayer's Avatar
No the Perrin is not the same as the Nisei Street FMIC. Nisei custom designed their FMIC. It's not an off-the-shelf intercooler so no other company has their design. Here's a comparison they did a long time ago. At the end, it lists most the of the major FMIC vendors including Perrin.
http://niseiengineering.com/images/CoreComparison.swf
Oh and if the Perrin FMIC fits with the stock piping, then the Nisei pipes should fit with the Perrin.
Old Oct 22, 2006 | 11:06 AM
  #80
NocturnalEVO's Avatar
  #81
Str8Ryda's Avatar
The Nisei and Perrin are very different. Take a look at Nisei's site and you'll see the tutorials where they show the difference between their core and others (like 7 makers).
Here are the dimensions of the Nisei versus Perrin.
Nisei Street = 25"L x 12 5/8"H x 3 1/2"T
Nisei Competition = 25"L x 12 5/8"H x 3 23/32"T
Perrin = 25"L x 11 7/8" x 3 1/2"T
Not only that but, both Nisei cores have 23 cooling tubes and Perrin has only 14.
Old Oct 22, 2006 | 12:49 PM
  #82
S1monLM's Avatar
Here's what i found from Garagehrs's site
●HPIインタークーラーキット
 ランエボ4~6(CN9A/CP9A)用 定価96600円 → キャンペーン特価 52290円
 ランエボ7&GT-A(CT9A)用 定価102900円 →キャンペーン特価 56700円
 ランエボ8&8MR(CT9A)用 定価102900円 →キャンペーン特価 56700円
 ランエボ9&9MR(CT9A)用 定価102900円 →キャンペーン特価 56700円
低圧損でありながら冷却能力を最大限に引きだすウエーブインナーフィンを超軽量コア内に装備.
圧損、冷却力、軽量化の三つの要素を高次元で実現した高性能インタークーラーキットが超特価
▼ WAVE INNER FIN(新開発ウエーブインナーフィン)
▼ アウタールーバーフィン(フィンにスリット入り)
▼ 軽量アルミコア
▼ V型トップ&ボトムプレート高耐久構造
▼ ANTI-RUST COATING(防錆のコーティングを施しています)
▼ 軽量サイドタンク(表面は磨いています)
Old Oct 22, 2006 | 02:30 PM
  #83
WhiteEvo05's Avatar
I knew I should've taken Japanese in school...
Old Oct 22, 2006 | 03:04 PM
  #84
Novtec1's Avatar
Veteran: Army
turbo xs....
Old Oct 22, 2006 | 04:37 PM
  #85
RED DEMON's Avatar
Old Oct 22, 2006 | 04:53 PM
  #86
diablo2184's Avatar
how does the Nisei compare to the AMS?
Old Oct 22, 2006 | 05:00 PM
  #87
binh's Avatar
Did you custom weld the side brackets on this intercooler or does it come like that from turboxs??
Originally Posted by Novtec1
turbo xs....
Old Oct 22, 2006 | 05:04 PM
  #88
Novtec1's Avatar
Veteran: Army
^^^^ comes with the brackets...
Old Oct 22, 2006 | 05:05 PM
  #89
the brackets come w/the turboxs fmic, they get bolted on to the car, not welded.
However he installed the brackets incorrectly. But they seem to do the job fine
Old Oct 22, 2006 | 05:12 PM
  #90
2003lancerevo8's Avatar
Not one of the AMS RACE mounts, very disappointed!!!
