JDM Flush - 18x9.5 +15s :)
Originally Posted by icedomin8r
Why run a 9.5 rim and only use 245's? What is the point?
not worth all the work to run 245s
with the "big ugly" body kits you are able to run a 275 in that wheel set up
which is 30mm more and the voltex wide front and rear fenders
look much better then that dent in your rear 1/4 panel
The pics look good. I like the looks of the 18" RPF1's but I don't agree with putting such a small tire on them. If it is a track car like you say than it should have some 275/35's or 285/30's on it
Yeah, I'm not a fan of the 245 on a 9.5" wide wheel either. If you're going to have your wheel stick out that far outside the wheel well, might as well have your tire wider and have that stick out as well. Or I would recommend just going with an 8.5" or 9" wide wheel with a 255 wide tire and still achieve the wide tire look but without the wheel sticking out so much.
