Old Jul 15, 2011 | 04:10 AM
  #5881
NocturnalEVO's Avatar
Originally Posted by JdmGraphiteMR
^you got oem body? cuz im rockin 18x11 -5 n it clears the suspension fine
what size tire are you running?
And how much can you turn the front wheels? Do the wheels hit the bumper or sideskirts when turning?
I imagine a setup like that would.. just wondering how you got it to work lol
I remember test fitting a +25mm spacer on a 18x9" +29 wheel, and it would hit my front bumper every time i turned the wheel.
Old Jul 15, 2011 | 05:51 AM
  #5882
Astro_Train's Avatar
Veteran: Navy
[QUOTE=bryant;9460757]18x10.5 +18's with 245's No pull. Just cut rears. Just sayin'
yea... you cut the fender... defeats the need for pulling....
245 is weak on a 10.5 but does give you the room for less camber and no pull(without cutting fenders)
I ran 245s on 18x9.5 +15s and I thought it was a bit of stretch. Not my cup of tea so I stuck with 18x9.5 +22 RE30s for the next set up(they are on order) and plan to start with a 255 or more likely 265s. Even at -2.5, tires will likely go fairly quick... mine were badly cupped on the inside at about 10k miles and I was at -2 all around and the EVO is not my DD.
Not flaming on people with stretched or mad crazy cambered EVOs... I was simply giving information to the person since he asked why most people run 9.5s over 10.5s and gave my personal experience with them... also people forget that the lower the offset of the wheel, the more camber you will have to run. If go below +20 offset on CT9As, you start playing with more negative camber which adds to increase tire cupping/wear. I personally think +22 is good offset for a 9.5" wheel on CT9As as you get the most meat/wheel under the fender without having to run a bunch of negative camber.
I want to see how 18x11s look on stock body CT9A... car is not made to run that kinda of width as the offset will likely be under +20 for sure... just go to widebody and call it a day... or get a X... someone already posted 18x11s on the X aggressive wheel thread. But Xs look better with 19x10.5s IMO. 18s look small on Xs.
Old Jul 15, 2011 | 06:58 AM
  #5883
SmurfZilla's Avatar
The 18X10.5 CE's look pretty cool. I don't think I'd do it. Its awesome to look at but I just can't get over the wheels sticking out from the fender. Love the lip....hate the poke.
Either way nice car.
Old Jul 15, 2011 | 10:47 AM
  #5884
Boltz.'s Avatar
FCOTM Winner
Originally Posted by NocturnalEVO
The fronts will hit your suspension. The rears will hit the control arms once you put tires on.
Will need spacers.
If you keep the ride height at a reasonable level, you won't need spacers. Clearing the sideskirts, fenders, bumper, liner is a different story.
To the guy looking to run the 18x11 +18, prepare for a LOT of work. It's going to be a big commitment. Even if you do something stupid like put a 235 on there, you're still going to have a TON of work to do. Not something for people who don't want to spend a lot of money or don't have the heart to start chopping away at their baby.
Old Jul 15, 2011 | 11:20 AM
  #5885
ViNZx_xD's Avatar
nice thread with lot of sick pic!! BUMP!
Old Jul 15, 2011 | 11:34 AM
  #5886
R/TErnie's Avatar
Will need spacers.
There are solutions for both of those problems. And the solution isn't pushing the wheel further outboard.
Old Jul 15, 2011 | 01:26 PM
  #5887
bryant's Avatar
[QUOTE=Astro_Train;9461774]
I hear what youre saying. Thats why I had another setup that was 18x9.5 +28 with 265's. I just wanted that lip and huge concave spokes is the look I was going for. Performance wise there are far better options out there.
And yes, Evo's eat front tires all day.
Old Jul 15, 2011 | 01:37 PM
  #5888
Watcha got?
Old Jul 15, 2011 | 02:50 PM
  #5889
Stormin Norman's Avatar
Originally Posted by ITOzann
you just gave me hopes that my 18x 11 +18 will work on the evo8. I don't want to sell them
Wheel offset calculator should have give you an idea:
http://www.1010tires.com/WheelOffsetCalculator.asp
+18 on an 11" wide wheel seems like it won't workout well.
I'm running 18 x 10.5 +15 with 275/35s and even that setup has too much stretch for my liking; should have ran 295s.
Old Jul 15, 2011 | 03:01 PM
  #5890
ITOzann's Avatar
Thanks for the input!
It might be stretch but remember not all tires run the same specs. Some brands stretch more and some turn to have more meat. Atm, I have 275's/295's mounted on the 11" wheels and there is no stretch on the 275's by any means(nitto NT01's/NT05's).
Anyways, I'll try my luck tomorrow and mount R1R 255/35's all around and see what happens.
Old Jul 15, 2011 | 03:10 PM
  #5891
goad_white03's Avatar
Diff run a 295, I have 285/30s on a 18x10.5 +15 and it still has a small stretch.
Old Jul 15, 2011 | 03:17 PM
  #5892
ITOzann's Avatar
30 profile will make the tires stretched from my experience.
Old Jul 15, 2011 | 03:38 PM
  #5893
im gona prob do 315/30s when i get new tires tho
Old Jul 15, 2011 | 03:53 PM
  #5894
ITOzann's Avatar
you can then buy my wheels Hhahahaah
Old Jul 15, 2011 | 10:44 PM
  #5895
JdmGraphiteMR's Avatar
tire size is a 295/30/18 yokohama S, but i using volte front fenders with the double over fender kit and the rear is a custom widebody with the double over fender kit, its actually the rootbeer evo a couple pages back, turn i can full rock no problem on hits my oil cooler so i gotta re-locate that but then again i have a greddy oil cooler and it sits back a little more if i had a stock one it would probably be fine. And aw doesnt hit bumper or sideskirt.
