Old Dec 9, 2014 | 02:26 PM
  #7306
benntrevv's Avatar
Originally Posted by TURBevO8
Not overly aggressive but first pics I took in a very long time so thought I would ***** them out. The typical +29 RGIIs.
Awesome car
Old Dec 9, 2014 | 02:27 PM
  #7307
benntrevv's Avatar
Old Dec 11, 2014 | 07:04 AM
  #7308
slowsrt4:('s Avatar
I have 255s on 18x9.5 +22, i'm guessing not aggressive, but also not stanced. Nobody wants this "regular" setup haha
Old Dec 13, 2014 | 12:28 PM
  #7309
SmurfZilla's Avatar
I would say anything 18X9.5 with a offset of +20 or lower is aggressive. Tire size is debatable.
Old Dec 15, 2014 | 08:49 AM
  #7310
polish_pounder's Avatar
Hey Everyone,
I would like some help. I have gone through nearly 400 pages of this thread and I am still struggling... I have 18x9.5+22 TE37SL Black Editions. I would like to leave my body as stock as possible. I have Seibon 10mm wider front fenders and the backs are rolled flat. I know I have to relocate or bend the rear bumper bolt but I need help on tires. I want a meaty setup. Can I fit a 265/35? My Ideal setup would be a 40 sidewall so would I be able to fit a 255/40?
Thanks for any help
Old Dec 15, 2014 | 09:33 AM
  #7311
R/TErnie's Avatar
Originally Posted by polish_pounder
Hey Everyone,
Thanks for any help
255's are going to be pushing it in the rear. expect to run a lot of camber to get them to fit.
Old Dec 15, 2014 | 09:56 AM
  #7312
Hey Everyone,
Thanks for any help
You will be needing a rear fender push to fit the 265 or the 255/40 & all the other tricks noted. BTW, if you cant run that set-up w/out adding out of spec rear camber, dont do it !!!
Old Dec 16, 2014 | 09:33 AM
  #7313
I know I will have to roll my rear quarters that is not an issue. I just hate the look of Pulled rears... How much camber are we talking? I feel like 1 1/2 - 2 deg. should be not too much right? Or is that a lot on our cars?
What about a 245/40? I could get this to fit you think?
Old Dec 16, 2014 | 12:09 PM
  #7314
Max rear camber from what Ive read & from my suspension tuner is 2 degrees for the road course. I run 1.8 at the track
Ran your no.s again w/the 245 which is the min width allowed for the 9.5". Sure it helps a bit but I feel the rear pull may still be needed for a full, no rub set up
Its the +22 & the 40 series that makes this tough as you know
Old Dec 16, 2014 | 03:47 PM
  #7315
yeah... I know lol. Thanks for the advice everyone
Old Dec 25, 2014 | 07:58 AM
  #7316
Mr. PSSsSt's Avatar
FCOTM Winner
Hey Everyone,
Thanks for any help
Here is a pic of when I was rocking 18x9.5 +22 Te37 with 255/35-18. Front fenders were rolled and rear had a slight pull and roll. Camber's were set to -2 up front and -1.5 in the rear. I had no rubbing issues.
902531_10151431573789023_145606545_o by Gotgr1p, on Flickr
Old Dec 25, 2014 | 07:09 PM
  #7317
au's Avatar
au
Hi,
I am looking for a more aggressive wheel stance for my JDM Evo 8 MR.
It sits right now on
Gram Lights 57 Maximum
18x8.5 +30
5x114.3
What spacers do you guys think I can run? 25 or 15?. I don't mind rolling fenders.
Here's a pic:
Thanks!
Ashish
Old Dec 25, 2014 | 07:19 PM
  #7318
Mr. PSSsSt's Avatar
FCOTM Winner
Originally Posted by au
Hi,
18x8.5 +30
5x114.3
Thanks!
Ashish
I think 15mm would be perfect.
  #7319
Hi,
18x8.5 +30
5x114.3
Here's a pic:
Thanks!
Ashish
You didnt note the tire size but they look like possible 255/35's?
You are already at +30. If you add a 5mm that gets you to an effective +25 which is very aggressive. You may need more than a roll w/just adding the 5mm
Imagine adding a +15mm spacer. Effective offset now at +15. Nobody runs a properly fitted +15!!!!
Old Dec 26, 2014 | 10:40 AM
  #7320
au's Avatar
au
It sits on a 265/35/18 tire.
I will double check the offset. have to take off the wheel.
I plan to add the Varis wide body thats why I need the spacers, cant afford new wheels right now.
