Universal FMIC
Old Mar 10, 2007 | 09:10 AM
  #31
dee_yamaha's Avatar
Originally Posted by 94AWDcoupe
Are you sure this core is 4 inch thick? My bet is its 3". I have never seen the apex style core in a 4" variety. The biggest I have seen is the 24 x12 x 3. Yoour statement that it clears the bumper beam pretty easily is also indicative that it is a 3" core. maybe you could actually measure it.
You are correct, its not even close to 4" the end tank is about 3.5 and the core is 3.....damn ebay description got me again. Thanks for pointing that out...I'll edit the description on the first page.
Old Mar 21, 2007 | 07:45 AM
  #32
FiftyFive's Avatar
Hey by any chance do you have pics of this with the front bumper off, so i could see how you mounted the brackets and licp exactly, thanks!
Old Mar 21, 2007 | 09:34 AM
  #33
iiirobbie's Avatar
yeah, i would like the see pics of the core alone. but it does look at lot better than the other ebay ones. as said before, looks a lot like an apexi core
Old Mar 22, 2007 | 05:26 PM
  #34
dee_yamaha's Avatar
Sorry guys but I dont have any pix w/the bumper off, when i do my next oil change I might have time to take it off and snap some pix.
Old Mar 27, 2007 | 03:56 PM
  #35
dee_yamaha's Avatar
Some closer look at the core and how the top is mounted using my own brackets....I have 2 other brackets located on the sides but is behind the bumper, I'll take more pix later.
Old Mar 27, 2007 | 04:00 PM
  #36
FiftyFive's Avatar
Where you mount the top brakcets too? where the stock intercooler mounts? If so did you weld a peice to go from the bard running horizontal in this picture to a bar that would be able to get to the original mounting location?
Old Mar 27, 2007 | 04:06 PM
  #37
blackblaze427's Avatar
is that a bar and plate core? looks like it
Old Mar 27, 2007 | 05:24 PM
  #38
dee_yamaha's Avatar
There are two bolt holes on the FMIC, so all i did was run a bracket that ran across then drill a hole w/ another bracket kinda like an L shape bracket to mount where the stock bracket was. The side I did the same, use a L bracket wedge it against the clamps and drill a hole to be bolted on the frame. I could've use more brackets on the bottom but its pretty sturdy.
Old May 8, 2007 | 07:26 PM
  #39
dee_yamaha's Avatar
Maybe someone with a apexi FMIC can post their pix and do a comparison.
Old Jun 16, 2007 | 09:32 PM
  #40
dee_yamaha's Avatar
Sorry took forever to post these, blew a intercooler coupler so had to take off the bumper... the brackets are kind of ghetto but it works, just need t-bolts instead of those screw on clamps.
<br>
<br>
Old Jun 17, 2007 | 12:29 PM
  #41
Exciting News's Avatar
shouldn't there be a concern about your brackets eating away at the piping from vibration?
Old Jun 17, 2007 | 12:46 PM
  #42
vortech_g35's Avatar
Not bad, thats a grip load of tq.
Old Jun 17, 2007 | 02:43 PM
  #43
dee_yamaha's Avatar
Good point man, I had it on since March and when I had the bumper off yesterday the piping was still good, maybe I'll put some rubber padding next time or get it welded.
dee_yamaha
Mid-Atlantic Region
819
May 31, 2016 09:03 AM
dee_yamaha
For Sale - Part Outs
Nov 30, 2008 12:00 PM
dee_yamaha
Mid-Atlantic Region
11
Aug 11, 2008 05:17 AM
dee_yamaha
Jun 30, 2008 06:16 PM
dee_yamaha
Mid-Atlantic Region
Apr 27, 2008 06:52 PM
