hood mesh help
Old Apr 10, 2007 | 06:26 PM
hondafan's Avatar
Question hood mesh help
hey, anyone want to give me some advice? my hood vent mesh is rock chipped and peeling and i was wondering how to get it off and what to use to strip the old paint off and repaint it. anyone that has some experience with this please offer up your advice. thanks.
Old Apr 10, 2007 | 06:28 PM
SEEnoEVO's Avatar
Same problem, and want to do the same thing. Subscribing.
Old Apr 10, 2007 | 08:24 PM
hondafan's Avatar
bump! c'mon, no one out there has repainted their mesh?
Old Apr 10, 2007 | 08:44 PM
craziazzmofo66's Avatar
the mesh or the luver plate?
Old Apr 10, 2007 | 08:46 PM
either way, if u wanna strip the paint off something small like that, u can sand it off or try some paint striper if u wanna. that paint on theres pretty light, so light sandins probably good, than buy a can of spray paint, and spray it.
Old Apr 10, 2007 | 08:47 PM
~BoOsTeR~'s Avatar
I would imagine removing the mesh would be as simple as unclipping the vent from the underside.
Remove mesh and soak in paint thinner for about 24 hours. Rinse, dry and spray with high temp paint of your choice.
Old Apr 11, 2007 | 09:22 AM
hondafan's Avatar
mesh. i'll try paint thinner as i don't think you can remove it all by sanding.
Old Apr 11, 2007 | 09:24 AM
TURBevO8's Avatar
My louvered plate is going to get repainted by me this weekend. My hood mesh is fine but the mesh on the front bumper is killed. I am subscribing too because when I finally remove the front bumper to take off the mesh and paint it, it would be nice to first strip it so it comes out perfect and one even surface.
Old Nov 19, 2012 | 08:41 PM
whtan's Avatar
bumping this, is it just as simple as removing a few clips?
Old Nov 19, 2012 | 09:13 PM
20psiboosting's Avatar
Plasti dip! 3-4 heavy coats, worked for me. Going on to a year now and still looking
like oem
Old Nov 20, 2012 | 04:26 AM
smoOVE's Avatar
scuff it down with a scuff pad and paint it. you do not need to remove all the paint.
Old Nov 20, 2012 | 07:35 AM
Pohjeekiller's Avatar
Used a small wire brush set from depot to remove as much of the chipped paint as possible then sprayed with high temp VHT engine paint...looks like new.
Old Nov 20, 2012 | 10:09 AM
YogSaahoth's Avatar
Veteran: Army
like oem
Combine these two pieces of advice and ur problem is solved. Get as much paint as you can off with wire brush and scuff pad (don't need to get it all just give it s good scuffing), clean well and paint with plasti-dip. I've used it on both hood mesh and front grill mesh and haven't lost a chip yet. Hood mesh will come right out...a few nuts and clips hold it in place.
Old Nov 20, 2012 | 10:11 AM
shrtstuff89's Avatar
With temps from the engine bay hitting it directly its a good idea to use high temp paint just in case, i used black caliper paint. Im happy with it.
Old Nov 20, 2012 | 10:59 AM
Trale.Lewous's Avatar
I started to do mine, and it's a huge *****. I then just took it to a shop and they did it.
