My front plate solution
you'll be getting pulled over again for sure
you can't even tell it's a license plate
here is what I did...used the same holes in the bumper with rubber grommets and a nut and a bolt...I eliminated the bracket
I think it looks really clean...I just had to drill new holes in the plate to make it wider for the screws
I live in a small hicktown where I get pulled over because my car has a wing. The week I bought my car I was pulled over and told my stock exhaust was too loud. After $225 worth of tickets in two weeks I had to put a front plate on. I think the stock location looks like **** and it disturbs the airflow over the front of the car. Not to mention YOU HAVE TO PUT HOLES IN THE BUMPER!!! I can unbolt that plate in 5 minutes and there won't be any holes in my bumper. I can put it somewhere else, but then it blocks flow to the i/c, o/c, or brake ducts. I've had that plate installed for over a month and haven't been pulled over once. I'm giving myself a pat on the back for a job well done.
I put mine over the mesh underneath the driver headlight. Zip tied it the mesh on the bottom holes then used rivets on the top 2 holes. Looks professional like it comes stock. No holes drilled. If the cops see it's a hack job they will give you another ticket for modifying something, especially if it's not at the right height where the stock plate mount comes factory. Good luck
beast66
For Sale - Cars For Sale
10
Aug 4, 2013 02:46 AM
