Pioneer AVH-P6500DVD...
Old Jul 27, 2003 | 08:52 PM
  #46
BlackLancer2k2's Avatar
i was gonna go for the pioneer DVD unit, but i ended up getting the clarion VRX935VD, it was a steal getting a brand new one for $700...i had to get it
Old Jul 27, 2003 | 10:01 PM
  #47
cky3396's Avatar
Originally posted by VA_LANCER_RACER
I had this on my old car http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3036578631 I was always hitting the thing at the top of parking spaces and messing up my body kit so with this I could pull all the way in and know just when to stop without cracking my bumper
id love to see a picture of where you mounted that.. if you've got one.
edit:
also, did your system detect when the car was in reverse?
mine does, but i'm not positive on how to get it working. I posted this in the tech forum, but i dont think ill get much luck there.
the pioneer instructions state:
Violet/white
Of the two lead wires connected to the back lamp, connect the one in which the voltage changes when the gear shift is in the REVERSE (R) position. This connection enables the unit to sense whether the car is moving forwards or backwards.
im thinking this means, the positive lead into the reverse light in the tails?
hmm, dunno. after i get this sorted out - ill do the neccessary tap work.
Old Jul 28, 2003 | 04:31 AM
  #48
GTVEVO's Avatar
BlackLancer2k2 that is the same unit that I have installed but I didn't get it for that price. If you don't mind me asking where did you purchase yours, I did a search and the cheapest place on the net was 1098.00. Regular retail is like 1899.99. I think that this one has the reverse hook up as well from what I remember, I will look to be sure.
Old Jul 28, 2003 | 12:25 PM
  #49
GTVEVO's Avatar
Ok I have attached additional pics of my full install. I have located my "Brain" in the Glove box so it doesn't get exposed to other people kicking it and liquid, that could be water from Snow this winter or If someone happens to spill somthing.
Old Jul 28, 2003 | 12:28 PM
  #50
GTVEVO's Avatar
Just the Brain Here
Old Jul 28, 2003 | 01:01 PM
  #51
cky3396's Avatar
geez that thing is big, nice place to put it tho. is there much room left in there?
Old Jul 28, 2003 | 01:18 PM
  #52
GTVEVO's Avatar
There is a little room left but I don't plan on putting anything else in there for now, I am going to do some Temp testing and if it gets to warm I am going to tap into the Passanger side Air Vent but all has been fine for the past 3 days but I haven't pushed it that hard either. As for the stuff that would normally be in there my manual and docs I keep in a binder in my house that way every reciept and EVO Doc is all together along with maint. records and documented magazine reports.
Old Aug 15, 2003 | 11:25 AM
  #53
johnjonfenomeno's Avatar
I have an AVX P7300 unit
Hi just wanted to know if you had to buy a din mount kit to install your unit. and also where did u mount the brain. In the trunk or on the floor? I have a avx P7300 unit and would like to know this info before installing.
Old Aug 15, 2003 | 11:53 AM
  #54
GTVEVO's Avatar
Currently They don't even make a DIN mount that I know of becasue the stock brackets work on ever install. The brain is in the glove box , pictures are posted above.
Old Aug 15, 2003 | 12:18 PM
  #55
JWERNER24's Avatar
In Timeout
hahaha, I just found this thread! I bought the Pioneer AVH-P6500DVD about a week before this thread was posted up on ebay also, only I got mine brand new with waranty for $949 + shipping. It ended up being around $975 shipped. I thought it was a pretty good deal, especially for the all in one unit! Nice to see others with the same toys...
Old Aug 15, 2003 | 12:51 PM
  #56
When you say stock bracket did you mean remove the brackets from the stock stereo and put them on the new unit? ... I prefeitted the din box that came with the unit and it seems to slide right inside the front mask. only thing is I would like to secure it because i know the weight of the head unit might collapse the front plastic fascia if that is all that is supporting it?
Old Aug 15, 2003 | 12:52 PM
  #57
TeamSlamDotCom's Avatar
In Timeout
Wow!
Old Aug 15, 2003 | 01:05 PM
  #58
GTVEVO's Avatar
yes I didn't use the Din Box at all becasue I took the brackets that Bolt into the dash and on the side of the unit. The brackets are very hard to get off usually so just FYI. But they will secure your unit.
Old Sep 3, 2003 | 11:45 PM
  #59
intimidator2000's Avatar
Vanilla sky does your CD/DVD player that you installed have a navgation system.
Old Sep 4, 2003 | 03:49 PM
  #60
cky3396's Avatar
nope. thats extra, and easily added
