some shots of my 600hp EVO 1
It's unreal how many newbies just hit reply and dont read the thread. The new wheels rock. Cannot imagine living somewhere that has those vintage cars running around. Looks great, has awesome trap speed. What turbo?
well had it back on the dyno last friday and made 430whp at 22psi dynodynamics 1.0 CF, ran into some ignition timing problems so need to sus it out before we go for more boost! I think i need to change the rear muffler, when on 18psi it would rev to 9k clean, now with more boost it drops 50whp from 8-9K, a straight thru should fix it.
thanks for the comments! 1d10t its a 35r .82.
just an update on the ****ter. Brakes were destroyed after powercruise so got some slotted rotors and new pads, rekon i should change the lines too? Also got some bearing's for the shifter cables, kind of tricky to install in the car though. They made a small difference to the shifting feel, my original bushes were in good condition so its not really that noticable, im yet to install the ralliart front engine mount i got so that might help also.
Ive had annoying oil leaks from the Tcase since powercruise, put 3 seals in it and still leaks, got a new yoke,uni and seal so this better cure the problem for good or i'll go nuts
Absolutely beatiful. ONe tiny thing though i think it would look alot better if you change the floor carpets to black. I think it would go really well with all that red. Once again awesome car man props
anyone done this before? Tailshaft circlip let go in 4th gear at WOT. Couldn't even find the yoke or uni and there were gouges in the road where the front of the tailshaft scraped.
