Lowered Stock Recaro Seat
Old Feb 15, 2008 | 08:48 AM
~EVILEVO~'s Avatar
Originally Posted by hopper
Wow since your a tad rude the link was just added Today at 07:48 AM.
sry dident mean to be rude the link was in his signature .... I just tring to help this guy sell his product...
Old Feb 15, 2008 | 03:56 PM
bbbwrx's Avatar
BUMP for a good seller!!!
I would not be worried about the quality for one second. Jared is the MAN!!
Old Feb 16, 2008 | 07:04 PM
jid2's Avatar
Created Installation Instructions HERE, so people can see what's involved https://www.evolutionm.net/forums/sh...15#post5292815
A few shots from them.
Old Feb 18, 2008 | 07:27 AM
jid2's Avatar
Thanks for the props, guy with the butt trumpet avatar (Ben) .
Old Feb 18, 2008 | 07:33 AM
~EVILEVO~'s Avatar
Any chances of a group buy anytime soon?
Old Feb 18, 2008 | 08:05 AM
jid2's Avatar
I'm not planning for one, at least at this point.
Old Feb 18, 2008 | 03:59 PM
jid2's Avatar
Looks like these will work for the SSL guys as well even with the amp under the seat.
Old Feb 18, 2008 | 08:38 PM
liberty2000rs's Avatar
Bump for a sweet product from an honest yet nerdy dude!!!
Old Feb 19, 2008 | 05:09 AM
Fireball's Avatar
I have these, and I love them!
One of the first batches ever made.
Old Feb 19, 2008 | 02:13 PM
jid2's Avatar
Moderator Approved! Fireball is indeed one of the O.G.'s of the low Recaros.
Do you still have the pictures you took? Especially that one from the front of the car which showed the difference in seat height.
Old Feb 19, 2008 | 03:24 PM
datrip's Avatar
i like that
Old Feb 19, 2008 | 09:52 PM
jid2's Avatar
Originally Posted by crazy_ugly_coyo
Ill take a set
Send me a PM or check this thread for payment details.
https://www.evolutionm.net/forums/sh...d.php?t=325589
Old Feb 19, 2008 | 10:41 PM
TougeGod7's Avatar
will these brackets hold up if you where to get in an accident?
Old Feb 19, 2008 | 11:19 PM
t51splbb's Avatar
Originally Posted by jid2@[BINARY]
I put the more info link in the first post, although it is in my signature also.
These are made from .125" thick mild steel, the stock parts are only .080" thick mild steel. So the base material is stronger. The geometry of the dropped brackets also drastically increases strength as the load from an incident will be along the long axis of the brackets putting them in nearly pure tension or compression. The stock brackets have a lot of bends which create moments, torque and more problematic loading. That's the toned down engineer response, I'm an engineer.
The simple answer is they are stronger than stock.
Your answer is on the first page of the thread.
Old Feb 20, 2008 | 12:27 PM
jid2's Avatar
A few people have had questions on strength in this thread and others. These brackets are as strong, if not stronger than stock.
The true weak point of the systems is most likely the M8 bolts which hold the sliders to the bracket - these are Mitsu factory parts. Clamping force from the torqued bolts help reduce the load on the bolt itself, but looking at parts individually the brackets have a yield point 2-3 higher than the M8 bolts.
Here's a screen shot from FEA (Finite Element Analysis) of the brackets, this was used during the design process to verify the strength.
