High Temp Paint for Hotside and O2Housing
What type of high temperature paint are you guys using to paint these type of parts. I just want to make sure i use something that reputable and wont crack or peel after a couple of weeks
If you want to use paint instead of an actual high-temp coating use one of the DuPond 2000*F paints available at most auto parts stores. The paints really won't keep heat in and underhood temps down though and it will eventually burn off.
mobman
Jan 29, 2010 10:38 AM
