View Poll Results: 18in or 17in
17in
227
47.29%
18in
253
52.71%
Voters: 480. You may not vote on this poll
18in or 17in
Old Dec 24, 2004 | 11:29 PM
  #121
turrizt's Avatar
Originally Posted by 19.5PSI
19" chrome. that's all i have to say about that. when you race someone, you'll blind them by the shine and that'll result in a win, for you.
essentially...
Old Feb 15, 2005 | 05:01 PM
  #122
Evojun8's Avatar
17's all the away to the line
Old Feb 24, 2005 | 09:04 AM
  #123
TomG's Avatar
There are a few missunderstandings about this whole thing.
The Evo got 17's stock, and it fits the stock suspension, the stock brakes, and the stock power.
But if you are modding you car, with coilovers, more power(on the other side of 300whp), going with a light weight 18's would not hurt performance.
A note on this is JGTC, where they run 18" in front and 17" in the rear, reason? ......better steering input, plus a little more sidewall in the rear(rwd)
As far as brake size goes, bigger brakes isnt always answer. I come from the gen2 MR2 enviroment, this last scc tuner challenge a mr2 with stock brakes, only upgraded pads and lines, stoped from 60 in 97ft....repeatedly.
The only reason to upgrade the EVO8 brakes is if you notice major brake fade during repeated braking. I doubt a bigger brake system will make it brake faster, i.e. I doubt the stockers is unable to lock the brakes without the ABS.
T
Old Feb 25, 2005 | 09:09 PM
  #124
alby988's Avatar
if you get 18in. wheels, does ur speedo get screwd up? can u fix it so it reads the right speeds?
Old Feb 26, 2005 | 04:34 AM
  #125
ttiscio's Avatar
I don't notice a difference in the seedo. Matches the GPS speed.
Old Feb 26, 2005 | 09:46 PM
  #126
osunick's Avatar
It shouldn't be off by more than a couple percent. When you get bigger wheels, the sidewalls of the tires are shorter, so the actual rolling diameter is almost exactly the same between 17" and 18" rolling stock.
Old Mar 2, 2005 | 11:39 AM
  #127
Theibault's Avatar
Just so you know, the circumference is the same wether you have 17" or 18" rims. It's the rubber that is lower profile to compensate.
Old Mar 2, 2005 | 11:43 AM
  #128
si_eater's Avatar
i say 17' s you go to 18 and if you dont lower the car will look like a pick-up
with 17 and wider cant go wrong and you wont need to lower
Old Mar 2, 2005 | 11:50 AM
  #129
osunick's Avatar
Yeah, we're pretty lucky actually, the rolling diameter difference between 17's and 18' is only about .01 inches:
Example: 235/45 R 17 = 235mm X 45% X 2 (sidewall height) /25.4 (convert to inches) + 17 =25.4 inch diameter X pi = 79.81 rolling circumference
235/40 R 18 = 79.80
The 18 inch wheel is a tiny, tiny bit smaller in terms of rolling diameter with rubber than the 17 but not significant.
The wider your rubber, the bigger the variance between tire circumference when you go up a wheel size, largely because the aspect ratio is only specified in multiples of 5. So 5% of 235 is smaller than 5% of 315.
Old Mar 2, 2005 | 12:14 PM
  #130
osunick's Avatar
What you just said makes no sense whatsoever. Since there's less rubber on the tires, the wheel/tire combo will look like they fill the wheelwells more. I haven't seen any pickup trucks running 40 series rubber besides crazy ones like the SRT-10.
Old Mar 2, 2005 | 12:25 PM
  #131
si_eater's Avatar
ok i got you yeah i didnt mention that if you decide to go with large tires . in my opinion i dont like the looks of my car being on blades or rubber coated rims(since tire is so thin) and risk busting my $1600 set of rims do t a freakin pot hole and since i race mine thin tires really dont convince me
Old Mar 23, 2005 | 09:53 AM
  #132
NoTiGuY's Avatar
one thing i can say, its sure bumpier on the 18"!
Old Mar 23, 2005 | 10:09 AM
  #133
Rez90's Avatar
i have volk TE-37's in bronze in an 18x8.5 and i love em although nitto tires suck my beanbag......don't ever buy them.....
Old Mar 23, 2005 | 10:41 AM
  #134
xtreme571's Avatar
22" Spinners...lol jp...i'd go with 17s...but as sum1 said it depends on ur local road conditions...around chicago...every road is ****** up...its mainly cuz of the snow...but thats jmo
Old Mar 23, 2005 | 10:28 PM
  #135
ezhangin's Avatar
Originally Posted by PAIDMADELAID
I think the tires would be the real factor regarding which is faster. Tires weigh a lot so if you got some light 18's with 35 tires you would be just as light or lighter than stock. Plus, the overall diameter would be close. The "Evo Orgy" article in Sport Compact Car had 8 Evo's tuned by different companies. About half of them ran 18's and half had 17's. Do you think companies like Works, RB, and XS Engineering would put 18's on their cars if they thought it would hurt performance? No way!
Ever hear of advertising?
