Any glare issues with the Gruppe-S Triple Gauge Panel with Defi Gauges?
Is anyone experiencing any glare issues with Defi gauges and the grupp-s triple gauge panel?
Also, do the AEM gauges fit without modification? I know they're a bit deeper then the Defi.
Thanks.
Thanks.
I dont have any issues with visibility, or glare with the defi gauges, and the gruppe s panel.
the only thing that you will have to think about with the AEM gauges when it comes to depth is the radio bracket that will sit behind the panel. I know that when I ran some Greddy gauges they were a little too deep, I ended up cutting out the radio bracket in there to make them fit. So keep that in mind.
The best thing that I think you could would be to mock them up before hand and see whats up. I know they will fit in the panel with no issues.
Good luck
caelin~
Good luck
caelin~
Maybe Gruppe-s will know specifically if the AEM gauge will fit or not. I'm not sure how the panel is from the back, but I figure if I can put the AEM in the middle then maybe it will fit.
I still have to figure out how to get the 52mm aem wideband gauge to fit the 60mm panel since my defi boost is 60mm.
I saw a pic of the panel without gauges in it and it seems the brackets for the panel are only a factor for gauges on the sides, the middle opening should be able to house the AEM gauge no problem.
Does anyone have any experiences?
i think any glare issue you may have will do more with the guage themselves than the gruppe-s panel.
I have the old Defi-D's and they glare at times, but not sure if you've seen Defi-D's before, they don't glow when your lights are off.
i have no real problems with my defi guages sometime in crazy sunlight you may have a little glare. The only reason I may be getting rid of mine is well the boost guage doesnt go high enough but ill wait till I change my setup for that lol.
Looks like I'll be going with this setup with the radio relocation here in the next week or so. I appreciate everyone's feedback, makes my decision a lot easier!
WTB[SouthEast]: Gruppe/autometer pod, AEM boost & Oil pres
Supergoslow
Apr 11, 2015 04:18 AM
gkmunch
Nov 19, 2009 06:43 AM
I4UnderPressure
Nov 10, 2008 01:05 PM
