Will this look good in the Evo?
Old Jun 5, 2008 | 05:45 PM
MitsuJDM's Avatar
Originally Posted by Evo_Someday
It would look nice but it won't work.
The only way a shifter gate would work is if the entire stick (top and bottom) moved when shifting gears while staying perfectly verticle. The stick on the Evo doesn't move like that - it only tilts from left to right as I go through the gears. The base of the stick stays almost perfectly in the center of the circle.
Check it out -- pictures of 1st gear and 5th gear.
Good point, but I think there is still chance of it working.
Good luck! Looks like a neat idea
Old Jun 5, 2008 | 05:46 PM
ChadB's Avatar
no.
Old Jun 5, 2008 | 05:49 PM
EvoKnievo's Avatar
EVO SOMEBODY just ed on your idea. this would be uber hard to do. especially if you wanted it to be like a ferrari or lambo.
Old Jun 5, 2008 | 06:04 PM
allan96817's Avatar
now try to take off the shift boot and go through the gears.... what makes you think that I won't raise the shift gate platform to match the angles on each gear? Like I said, I did measurements on everything, all I need is the labor...
But a very good point , it was one of the biggest questions that we had to brainstorm on(4 guys in a garage with beer in hand )
Old Jun 5, 2008 | 07:10 PM
EvilToaster101's Avatar
If you could get it to work it would look very good and it would make the interior of your car stand out, lets face it the evo interior is bland. Good luck post pics if you get it!!
Old Jun 6, 2008 | 08:20 AM
Evo_Someday's Avatar
Well ok - that might work if you raise the entire center console up and gate it just below the shifter ball. Sounds like a lot of challening fabrication work to make it look right.
Even then I'm still not sure it can be done because it looks like the spacing from one "slot" to the next (1 to 3 for example) is so close that there may not be enough room for a separator spline.
In anycase, I'd be interested to see the outcome. Good luck. Post pictures if you do it.
Old Jun 6, 2008 | 08:25 AM
4G63's Avatar
I'd like to see how functional/normal you could make it.
Old Jun 6, 2008 | 08:27 AM
migs647's Avatar
Originally Posted by Jeffroevoix
I sure it would look good, but if I forgot to close my ashtray I would lose all my change when I take off.
Isn't that what the change drawer is for next to the hood release ;p
Old Jun 6, 2008 | 08:28 AM
migs647's Avatar
I think it's possible. I think there might even be a market for these!
Old Jun 6, 2008 | 08:40 AM
Jeffroevoix's Avatar
The IX's have the interior light dimmer there. No change cubby.
Old Jun 6, 2008 | 08:43 AM
tabio42's Avatar
Like EvoSomeday pointed out - the pivot point is pretty high on the shifter. Why don't you just make a really nice billet cover without shift gates? You can still mill the gear indicators into it. That way people with all different kinds of short throw shifters can use it too.
Old Jun 6, 2008 | 08:47 AM
lexat20's Avatar
That would look awesome but I think it should be left for the Ferraris
dave_evolvix's Avatar
I give you props for the idea, and you are welcome to try, if it works I'll be one of the first to congratulate you. But I don't see it working unless the gates are very high off the floor.
Old Jun 6, 2008 | 08:56 AM
Contagious216's Avatar
i so go for it it might look kinda cool, i know i havent seen it before on an evo thats for sure
Old Jun 6, 2008 | 12:56 PM
jdmdc2r01's Avatar
I don't like it. It kinda makes it look cheap. Like an add on from something like pepboys. I'd say the stock boot looks good enough. Just my opinion
