Full Flat-Bottom Undertray EVO
Old Jun 16, 2008 | 10:31 AM
  #46
Indy Evo's Avatar
Thanks, tell Riz, Mark, and Wes hello for me. Jim
Old Jun 16, 2008 | 11:34 AM
  #47
Ludikraut's Avatar
Originally Posted by jid2@[BINARY]
...For the rear diffuser I plan to cut out the rear bumper to the level of that spare tire well so the diffuser can transition up the back of the car. To balance cost, and performance the rear diffuser will most likely be thermoformed plastic of some sort. Sheet metal is kinda ugly and not easy to make with nice curves without expensive tooling. Carbon is great but $$$$ and I'm not into fiberglass with a carbon top sheet. So thermoforming seems to be a good fit. That project is a little bigger undertaking.
Why not make the rear diffuser out of aluminum? Also, if you're looking into possibly making it a production piece, then cutting of the rear bumper is probably not practical. IMO the best rear diffuser so far for the Evo was the one that Paul Gerrard helped design for Vishnu, although I do think that it could be improved upon.
l8r)
Old Jun 16, 2008 | 06:22 PM
  #48
mr_brightside's Avatar
good luck with the project.
Old Jun 17, 2008 | 05:17 PM
  #49
Tom-05-MR's Avatar
Currently the panel stops at about the rear axle and the diff is totally in the open air, unmolested by the underpanel!
Well, the thing is that the rear diff is engineered to have under-car air flowing across it, so even if the back's exposed, it's not receiving the airflow from the front that it's designed to have. Additionally, once you've got your rear diffuser rigged up you'll be completely sealed off. Just keep an eye on it
Old Jun 17, 2008 | 07:01 PM
  #50
jid2's Avatar
As I said, the diff is completely in the open - not the back, the whole diff. The rear diffuser will not be covering the diff either.
Old Jun 17, 2008 | 07:05 PM
  #51
SyZyGy1394's Avatar
wrap the exhaust....
Old Jun 17, 2008 | 07:13 PM
  #52
Vostok 7's Avatar
HMMMM I need something like this. I'd need some custom work though I'll definitely be putting them to good use and testing their effectiveness properly... And I'm in WA! Let's talk I'll be over there tomorrow (actually, I have to go to Speedware to pick up some stuff) so I might be in your area.
- Patrick
Old Jun 17, 2008 | 07:25 PM
  #53
Done's Avatar
get some test data, it defiantly looks cool!!
Old Jun 17, 2008 | 07:53 PM
  #54
jid2's Avatar
- Patrick
I'll be at Pacific Raceways tomorrow, I leave work at lunch!
Old Jun 17, 2008 | 08:15 PM
  #55
Vostok 7's Avatar
Bah! I'm leaving Thursday for a race. PM me and let's talk. I can certainly do some good tests, the type of racing we do is sustained high speeds (usually 130-140mph over 100mi) and as you can imagine aerodynamics are a huge concern of mine.
- Patrick
Old Jun 17, 2008 | 09:46 PM
  #56
jid2's Avatar
- Patrick
Fo_Sho, are you doing open road challenge type of stuff like the Silver State Classic?
I just got back from my first real drive with the underpanel, it was just across town to get gas... But the engine came up to full temp and I made a few pulls. When I got home I immediately got out and put my hand on the aluminum underpanel directly under the exhaust it was COLD to the touch, not even warm. By no means is this anything conclusive, but it's a better sign than it being HOT!
Old Jun 17, 2008 | 09:48 PM
  #57
geektunedevo's Avatar
pretty slick!
Old Jun 17, 2008 | 10:01 PM
  #58
Vostok 7's Avatar
Yep! Silver State Classic Challenge. And others, this weekend we're heading to the Bonneville 100.
- Patrick
Old Jun 18, 2008 | 02:22 AM
  #59
dannys EVO IX's Avatar
huh........
i was trying to come up w some like this, hahaha .........
id love to see the final product, good job BTW
Old Jun 18, 2008 | 08:20 AM
  #60
jid2's Avatar
Drove 50 miles to work today, first half is cruising at 70 mph, second half is cruising at 40 mph, with occasional stops. Got to work - underpannel COLD.
We'll see how it does this afternoon at the track.
