Official: RE-PAINTED BREMBO's Thread
Old Dec 12, 2012 | 10:00 PM
  #946
Riddle's Avatar
Originally Posted by EVOEvolved
All depends on what you want? I feel powder coating gives you only so many colors.
Looking for black or silver nothing special
Old Dec 13, 2012 | 10:46 AM
  #947
Mistaken's Avatar
Originally Posted by Riddle
What's a good place to get them powder coated? Can't seem to get in touch with Tirado Custom Coatings
Look for a local powder coater in your area. There should be a few.
You can pick any color you want.
Old Dec 13, 2012 | 11:03 AM
  #948
spdracr83's Avatar
There are literally thousands of colors to choose from. So I don't know why u said powder coating only gives u so many colors.
Old Jan 3, 2013 | 06:37 PM
  #949
Hereknorthere's Avatar
Originally Posted by 95TSIAWD$
There's a reason why it was so cheap, for one those brakes are not blasted. I do a set of brembos every week or so and that black look is a coating from the factory under the paint that needs blasted off, secondly they coated your brakes assembled (at least the rears) in a few short months you will be going back there asking for your money back because what they did was seal the 2 halves together well vibrations, heat, etc will cause that powder to fail and start to lift/flake/peel all from around there. Thirdly, it looks as though they were coated with the pistons/dustboots installed. Do they have any idea what kind of liability that is now that your brakes may fail on you? Just because it looks pretty does not mean it was a good job. If you'd like I will call them to explain how badly they messed up and to fix it before you end up losing your brakes and get into an accident.
That coating is a ceramic coating and it is there for a reason...to help keep the heat transfer down from the rotors. The calipers should be stripped, not blasted...that is if the car is to be driven like is was meant to be.
Old Jan 3, 2013 | 08:42 PM
  #950
car_nut15's Avatar
Here is what they should look like when they are completely sandblasted, I just blasted these tonight to coat tomorrow:
Here are some that I have done in the past:
can you pm me a quote on how much to coat mine in the factory red with the oem brembo logos??
Attached Thumbnails Official: RE-PAINTED BREMBO's Thread-29345_359291937500468_1676672180_n.jpg   Official: RE-PAINTED BREMBO's Thread-dscf0858.jpg   Official: RE-PAINTED BREMBO's Thread-404204_188180607944936_100002589942849_335748_1592659719_n-1.jpg   Official: RE-PAINTED BREMBO's Thread-403141_223620281067635_100002589942849_418618_340720895_n.jpg   Official: RE-PAINTED BREMBO's Thread-376083_192052954224368_100002589942849_349713_168373416_n.jpg
Old Jan 6, 2013 | 11:36 AM
  #951
spyda494's Avatar
Damn all these look so nice.. Does anyone have a pic of their black evo with white brembo? I, debating to go white or back to red
Old Jan 6, 2013 | 11:31 PM
  #952
norcalbmxxx's Avatar
^^^This is exactly what Im going for flat black evo with flat black wheels and hoping that if I go with white calipers they really pop against the car. New pads arrived today and painting this week sometime more than likely. If someone doesnt post pics I will definitely post how mine turn out.
Old Jan 8, 2013 | 11:08 AM
  #953
siikEvo92's Avatar
Officially pulled the trigger on rebuild/ powdercoat. Have a 03 RR can't decide between dark candy apple red or pearl white.
Old Jan 8, 2013 | 11:26 AM
  #954
SSickLS1's Avatar
id stay away from white unless you want to clean them daily
Old Jan 8, 2013 | 01:51 PM
  #955
Carvs's Avatar
I don't know how I missed this thread months ago....
Old Jan 8, 2013 | 02:34 PM
  #956
Extreme Dimensions's Avatar
Originally Posted by manray
+1 on this. Was planning to go this route before I sold my car
this is the way it should have been done from the beginning! so clean and simple!
Old Jan 8, 2013 | 03:39 PM
  #957
DSMolition's Avatar
I did mine the other day all myself. I powder coated them transparent candy red after a good media blast. Also added hawk hps pads, power slot rotors, goodridge brake lines, and ate super blue. I am going to do the rears next week. I like how they came out!
Attached Thumbnails Official: RE-PAINTED BREMBO's Thread-brembcandyred.jpg   Official: RE-PAINTED BREMBO's Thread-candyredbrem.jpg
Old Jan 9, 2013 | 04:43 AM
  #958
siikEvo92's Avatar
Car isn't a daily, weekends only
Old Jan 9, 2013 | 08:31 AM
  #959
SavEVOIX's Avatar
Originally Posted by VR4Babe13
Always start with the caliper furthest from the master cylinder . Where are you located? Once you remove the calipers, you're allowing air into the system, hence why they need to be bled. If you need more info, PM me . I powdercoat but Im a mechanic so if you're local I could just do it all. If not, I can just help you.
EDIT: Just noticed you're in california, so I guess I will be helping online! lol
WRONG lmao
http://www.joe250.com/cars/evo8/brak...ebleeding.html
Old Jan 9, 2013 | 10:12 AM
  #960
Mistaken's Avatar
Looks good but Id get bigger BREMBO stickers for them.
