Stevo's Custom CT9A Head Lights (Bling Edition)
Hmm, I can't think of a reason why the the USDM CT9A projector is unmodable. Wouldn't mind playing around with one of these to find out why. Wot the "washer mod" does is change the focal point of the lense to some how get more of the blue band. You can also reposition the cutoff shield further/closer to the lense but I have never tried this mod. Theres also "spacing out the bulb". This mod is may stretch your blue band wider across the beam pattern but it also reduces the brightness.
The washer mod is definstely the easiest to do.
Will try n source some cutoff shield pix for ya. Remember seeing it sumwhere. Prolly one of the retro fitting sites that I mentioned b4.
http://www.hidplanet.com/forums/view...hlight=evo+mod
id really like to mod my projectors so there is more blue. I think i read somewhere that they are unmoddable beacasue the cut off sheild is attatched to the projctor? is that the reason why?
thanks
Looks good. I have the TSX projector retrofit in mine along with small modifications to increase intensity, width and cut-off
. I originally wanted to do the FX35 + TSX hybrid, but the housing didn't give me enough room to do so.
Some pics:
. I originally wanted to do the FX35 + TSX hybrid, but the housing didn't give me enough room to do so.Some pics:
Dont go TFX!! Although it is one of the best small sized Bi-Xenon (Low & Beam) projectors, theyre are not renouned for WIDTH. This projector is good for retros where you:
- need a low and high beam for a "Reflector" style headlight housing that has low and high beam all in one eg. CP9A's (Evo's IV - IV)
or
- want to beef up your high beam. This set up on a CT9A will create a quad High beam (how often do you drive with your high beam on?)
Enjoy the wider projectors (S2000 or TSX) coz low beam is where you spend most of your time night driving.
TSX maybe easier to install in the CT9A low beam housing due having 2 mounting screw holes each side.
S2000 will require you to fabricate some brackets but this extra effort is worth it in the end.
S2000 projector:
Also, as requested. Pics of halos that I found. Dont go too blue. I recommend white (4300 - 4500K halos)
http://img134.imageshack.us/img134/1710/haloshs8.jpg
http://i264.photobucket.com/albums/i...ncer/evo1h.jpg
USDM = "step" cutoff shield
JDM = "slope" cutoff shield
As I mentioned before, I achieved that blue band by using the "washer mod" only (4 x card board rings).
What mod is done to INCREASE width???
FX35 will fit in the CT9A low beam housing:
ievovii please post more on the "retrofit" ive been wanting to do this for some time now but will be having someone do it for me probally lightwerkz.net cause there close to me and the price is not that bad. please post pics when lights are on your car
These wont be on the car for a while. Im accumulating all my other mods together (custom tail lights, custom interior panels). Once the car comes out of the panel shop with the widebody installed then I will fit all these parts.
However, i will be posting light output pics when the heads are done. Just not on the car!!
I have heard from members on EvoOz detailing that the non HID projectors disperse the light differently when subjected to HID lighting. None of these ppl have supplied any light output pix to suggest this occurance. I personally havent seen pix to suggest this either.
If anyone here is using HID in a non HID headlight could that please post some light output pix. say 10ft, 30ft + 60ft.
Also post any pix of the non HID projector bowl to compare with mine
This is the bowl design of my HID VIIIMR projector
