C/F trunklid dampers?
Old Feb 9, 2009 | 10:45 AM
QwikEVO's Avatar
Is there such a beast? If so, where can I get some? The search button brings up numerous threads on hood dampers, but nothing for the trunks.
Old Feb 13, 2009 | 11:50 AM
4g63tFan@tic's Avatar
I have never come across any trunk dampers, as they probably would not fit due to the weatherstripping seal on the trunk. The trunk uses torsion springs to pop open. It would most likely be a custom install, that would negate the cost.
Old Feb 13, 2009 | 12:05 PM
05ah8james's Avatar
Thats a good idea! Never even though of it.
Old Feb 13, 2009 | 12:12 PM
jjm4life's Avatar
not sure what the use for these would be as the trunk already stays open on its own, unlike the hood. if youre looking for something because the trunk springs up too fast because youre wingless or have a cf trunk, get the springs for an rs trunk, it will open much slower.
Old Feb 13, 2009 | 12:17 PM
Babs's Avatar
only hatches really use dampers...my old rsx used dampers and there were aftermarket ones available for if you had the type-r wing since it's heavier. there's no need for dampers for a trunk that stays open on its own
Old Feb 13, 2009 | 01:10 PM
Titaztik's Avatar
There is some available...
I had them on my old Lancer when I had my CF trunk. Redline tuning makes them. Here is the link to it:
http://www.redlinetuning.com/QL-MITS...RUNK-0207.html
Old Feb 13, 2009 | 02:21 PM
JDMevoBOOST's Avatar
If you have ever had a CF trunk or trunk w/ no wing you would know what use these are. With the stock trunk torsion bars the CF trunk or wingless trunk flies up pretty violently without the weight of the wing there.
Old Feb 13, 2009 | 02:53 PM
jjm4life's Avatar
^^^ thats why i recommended using the torsion bars from a RS. besides, those trunk dampers looks retarded.
Jsiebert
Sep 9, 2015 08:16 AM
jameswwt
31
Aug 4, 2011 01:00 PM
soontobe
Jun 30, 2009 11:19 AM
theEVOdream
32
Jun 4, 2008 03:26 PM
kronic420haze
Lancer Engine Tech
27
May 5, 2008 02:23 PM
