Boring sunday turns into an engine swap
Old Sep 14, 2009 | 07:33 PM
  #61
sikwititevo9's Avatar
downpipe and intercooler piping look awesome. definately give you props on that. when i did my custom turbo set i also did my own downpipe fabrication and believe me i know how big a pain it can be. one question though whats so special about the dual bov?
Old Sep 15, 2009 | 02:14 AM
  #62
demodeakin's Avatar
Looks Great........ That is some clean Fabrication, I think that is the First Mounting I have seen for a Meth pump on the Tranny looks pretty good.
Thanks for the Bad News on the T-Case but I will do a Partial Pull and Should be pretty easy to disconnect.
Deak
Old Sep 16, 2009 | 05:43 AM
  #63
antilag_200's Avatar
thank you for all the comments everyone.. I appreciate them...
sikwititevo9 --- the twin BOV valve theory has to do with driveability in my cars set up. each valve has different spring rate . Therefore under varying degrees of engine load ( both vacuum and boost), each valve shall react accordingly.. It was simply an experiment that I was doing with the car and consequently found that it worked for me.
Not much to report people.. I was busy playing golf all day yesterday for a work outing.. so I did not have time to mess with the car. I have however completed some small miscelaneous stuff, like replaced the hub assembly on the passenger side, had to make a new connector for my defi oil pressure sensor, and new vacuum lines for the wastegate.
today I will be receiving the rest of my bends for the wastegate dump. So hopefully I can fabricate that tonight, have everything welded by tomorrow and with some luck, fire this thing up by friday
Old Sep 16, 2009 | 09:35 AM
  #64
evo8jedi's Avatar
Thats a sick build...
I've done the same thing to one of my old clutches in my old evo...
Old Sep 16, 2009 | 12:33 PM
  #65
lostkoz's Avatar
Looks like everything is coming along nicely.
Im glad that you are putting that manifold to good use!
nice job!!!
Old Sep 16, 2009 | 12:42 PM
  #66
^kris, thank you for selling that work of art to me... that manifold is absolutely epic under the hood of my car.
I told you it was going to a good home
Old Sep 16, 2009 | 02:31 PM
  #67
lostkoz's Avatar
Yes it looks awesome, I'm glad you enjoy it. The black matches well with the engine bay.
You will have to post some videos after you get it up and running.
Old Sep 16, 2009 | 04:50 PM
  #68
jessepesc's Avatar
nice
Old Sep 16, 2009 | 05:18 PM
  #69
brenner's Avatar
very very impressive. cant wait till things settle down for me and i can start putting things together like this for my car.
looking forward to the updates to come.
bren
Old Sep 16, 2009 | 05:20 PM
  #70
Norcal4G's Avatar
nice
Old Sep 17, 2009 | 04:57 AM
  #71
Kris-- I will definitely post some videos once it is done.
Thank you for the comments everyone, I truly appreciate them.
PROGRESS REPORT:
Yesterday We finished up the dumptube, thank you Chris and steve for all the help.
on to the pictures
I am using 1.625 ID 304 SS for the construction of the dump tube.
From the top. Basically the gate dump faces the block, makes a 90 degree bend towards the powersteering, then a 90 degree down to the floor, ending with a maybe 30 degree kick. We did this, so that it looks asthetically pleasing to the eye ( i.e all the pipes are in the same relative geometric plane to each other.
Top view
the kick towards the power steering
The bend directly out of the gate ( boy is it tight in there)
side view by the downpipe
a better shot by the down pipe
under side view
and a better shot from the underside
thats finally it for fabrication.Also we marked the location of The O2 bungs ( which are also SS). Everything will be welded up this evening. My buddy Chris will weld all this up, because I do not have stainless wire in my welder. Plus I think you are supposed to use Argon gas when welding stainless. Oh everything will be migged because I also do not have access to a Tig welder.
hope you have enjoyed the little fab work.
Things left to do:
1) Shave the front motor mount bracket so that the Intake pipe can clear it
2) Add fluids to everything
3) Bleed the Hydro TOB
4) build the -4 AN pro lite vacuum hoses to the Wastegate..
5) fire it
6) beat the **** out of it
Its getting close people..
Old Sep 17, 2009 | 05:16 AM
  #72
evoooo's Avatar
next time your having a boring sunday, why not help me swap out my clutch??? sweet! good job btw bro, coming a long great.
Old Sep 19, 2009 | 09:14 AM
  #73
justa4banger's Avatar
damn nice build... great fabrication on the lower pipe and wastegate dump
Old Sep 19, 2009 | 10:58 AM
  #74
tweaker41's Avatar
Nice build. That's some good fabrication!
Old Sep 20, 2009 | 05:34 AM
  #75
Imports14life's Avatar
Awesome work man. The fabrication is great, can tell you took your time to do it right.
Cant wait to see how she turns out. Got any plans to get it on the dyno anytime soon?
