polished hood
Old Jul 6, 2011 | 04:27 AM
  #331
MonstarEVO's Avatar
interesting. You'll definitely be seen on sunny days. Hopefully the cops don't fuss about it.
Old Jul 6, 2011 | 07:52 AM
  #332
Evolento's Avatar
Originally Posted by IbeBOOSTIN
This hood looks very nice!!
Big props on it
If you ever wanna sale it I'll buy it off you
thanks man.
Also to answer some questions bout corrosion on polished aluminum
Try using clear.. A nice coat or two of clear will help protect it n give that
Extra lil bling factor I've personally done this on lca valve cover for honda/integra
N no problems here
Do research before you try n knock me as well as don't buy cheap ish
never had the corrosion problem, my friend with his polished hood miata has his outside and drives it everyday hasn't either.
lol yep. Break a lot of necks in traffic. Cops hasn't as of yet. One gave me a compliment
Old Jul 6, 2011 | 08:44 AM
  #333
95gst16g's Avatar
I honesty don't think it looks too bad...I didn't read every post but how long did this take you!? I don't even have the patience to do a valve cover...lol
Old Jul 6, 2011 | 08:47 AM
  #334
Evolento's Avatar
Didn't time myself really, I did it a little here and a little there since this wasn't my main hood, just an extra.
Depends on the hood I guess, but if I had to round it off, definitely would say its a full days project.
Originally Posted by Evolento
hmm lets see if I can do a quick write up.
You will need to buy aircraft stripper from your local discount auto parts. It's in a decent size tin container. It's a gel like substance, and it costs around $17.
I laid the hood on top of some plastic chairs to elevate it from the floor, and started spreading the gel with a paint brush all over the top of the hood.
Let it sit for a few hours so it can eat at the paint, it wont damage the aluminum.
I used a pressure washer to remove the excess paint that was dangling on the hood so I don't scratch the hood...do not use a razor......you can use a plastic spatula of the sort. Something that is semi firm but flexible.
^that process will need to be repeated a few times until everything is removed.
After the paint and primer is off, I started WET sanding the imperfections and all. Started with 600, then 800, 1000, 1500, then 2000. Wet sand in an up and down motion, not circular. I noticed it worked better that way.
Then polish it up, I forgot the exact compounds used because my friends was doing most of the polishing with their brands etc, but I'm pretty sure most will work. Buffers definitely help to finish the polishing process a lot quicker lol.
Old Jul 6, 2011 | 08:54 AM
  #335
95gst16g's Avatar
Yeah I work at a bodyshop and just stripping a hood is a chore itself! I don't think it looks bad on your car.it is different.now lets see a polished hood,roof,and trunk on a rs! Haha
Old Jul 6, 2011 | 09:01 AM
  #336
Evolento's Avatar
MR's, RS's and SE's can do the roof as well, trunk is steel sadly
Old Jul 6, 2011 | 12:06 PM
  #337
95gst16g's Avatar
Ohhh really...nice to know.I'm a evo noob came from dsms I thought only the rs had the aluminum skin.That's wierd the trunk is steel I assumed it would be aluminum if they went through the trouble of doing the whole roof skin...
Old Jul 6, 2011 | 12:10 PM
  #338
kanyonkid's Avatar
hood looks good, but not on a yellow car. A tb evo would look nice with polish rims.
who did the work for you and what did it cost?
Old Jul 6, 2011 | 12:47 PM
  #339
BOOSTINAT30PSI's Avatar
Actually i have a 04 rs and its steel also...
Old Jul 6, 2011 | 08:01 PM
  #340
Evolento's Avatar
I did it.
sorry, forgot to say 05+ RS's
Old Jul 6, 2011 | 11:07 PM
  #341
rong.'s Avatar
Did you seal it after you polished it to keep up that sweet shine? I love it, you are definately the man!
Old Jul 6, 2011 | 11:08 PM
  #342
TravEvoIsBeast's Avatar
Different, would look better on black imo
Old Jul 6, 2011 | 11:16 PM
  #343
Evolento's Avatar
no seal, I keep it up lol. Then again, I don't use the polish one everyday.
indeed, someone do it!
Old Jul 7, 2011 | 10:40 AM
  #344
I bought another hood... Same color as my car.. So im gonna throw it on.. And the gray one i bought not too long ago... Is gonna get polished...
Old Jul 7, 2011 | 08:03 PM
  #345
Evolento's Avatar
