Odyssey 680 install pics
Old Nov 3, 2003 | 06:22 PM
bishiboy's Avatar
There are plenty of block and such out there for auto stereos.
Old Nov 3, 2003 | 06:31 PM
Quickshift's Avatar
Hey wut are the cold cranking amps on it?
Old Nov 3, 2003 | 06:33 PM
Quickshift's Avatar
Battery looks identical to buschars battery
Old Nov 3, 2003 | 06:44 PM
bishiboy's Avatar
Specs:
5 second cranking amps: 680
Cold Cranking Amps: 280
Weight: 14.7 lbs
measurements: Length- 7 9/32" x Depth - 3 1/8" x
Height- 6 11/32"
Old Nov 3, 2003 | 06:45 PM
Mister2zx3's Avatar
Did you weight the new battery and the stock one? Great weight savings and lower placement! That is under the passenger seat as well, correct?
Old Nov 3, 2003 | 06:47 PM
bishiboy's Avatar
Didn't weigh the stock. Odyssey 14.7lbs. It's under passenger seat.
Old Nov 3, 2003 | 06:50 PM
Quickshift's Avatar
I wonder how 280 cca will work in around 15-30 degree weather in the winter
Old Nov 4, 2003 | 07:31 AM
TearItUpSports's Avatar
That is a great battery and the one i intend to use in my Evo eventually. I do live in TX though, where it is warm enough to use it year round.
Northerners may only want to use this in the summer.
A couple warnings. Be prepared for frequent jump starts. If you leave your lights on for 15 minutes or your stereo on a while (without the car running of course) it will completly drain the battery.
Also with this mod located in the passenger cabin, you will not be able to ever run an SCCA autocross or probably any track events either. Also any drag strip that actually does tech inspections, will probably not allow you to run either.
Old Nov 4, 2003 | 07:52 AM
chronohunter's Avatar
good points all. Probably better of putting the stock battery in the trunk if you are going to do any racing (in an approved box) and that would help weight distribution (not overall weight) a little more too...
Old Nov 9, 2003 | 03:23 PM
smanders's Avatar
Would placing it in your trunk prevent you from running, autox, track events, etc...? Also what exactly is an "approved box" to house a battery?
Thanks,
smanders
Old Nov 13, 2003 | 03:26 PM
ducatist921's Avatar
Definitely a mod to consider, save at least 20lbs.
Old Mar 27, 2004 | 10:49 AM
bishiboy's Avatar
I am considering a stereo upgrade. I think a Cap will help. Anybody else upgrade stereo with minibattery?
Old Jun 3, 2015 | 11:39 AM
evoVI_PR's Avatar
Sorry to bring back such an old thread.
If these Odyssey batteries are sealed and do not leak acid or anything like that, why would they not be allowed in track events? As long as a fuse or breaker is used, near positive terminal, there would be no fire risk.
I'm thinking of doing this mod and I do occasionally participate in road race time attack events.
Thanks,
JCG
ZanarkO
Feb 19, 2016 02:22 PM
Jsiebert
Sep 9, 2015 08:16 AM
SmurfZilla
Aug 16, 2015 03:50 PM
elkazX
For Sale - Wheels / Tires
Aug 13, 2015 04:01 PM
