Ralfi´s pride and joy
Old Oct 12, 2011 | 07:45 PM
  #91
FLOW1's Avatar
Such badass rides....
Old Oct 12, 2011 | 08:11 PM
  #92
R/TErnie's Avatar
You need a TRE MAX LOCK rear differential!!!! Then you can POWERSLIDE
Old Oct 13, 2011 | 12:59 AM
  #93
ralfi's Avatar
I don't want to Powerslide. I want to be fast...
Old Oct 13, 2011 | 06:16 AM
  #94
R/TErnie's Avatar
Understeering isn't fast
Old Oct 13, 2011 | 07:14 AM
  #95
ralfi's Avatar
Where do you see understeer?
Old Oct 13, 2011 | 08:05 AM
  #96
R/TErnie's Avatar
If you have to flick the car to produce snap oversteer... your turn in sucks.
I promise your car will push on turn in and mid corner...and probably will push on corner exit.
Old Oct 13, 2011 | 08:23 AM
  #97
NJ9MR's Avatar
FCOTM Winner
Your cars and what you have done to them is just amazing! Great work! Looking forward to MORE updates! Thank YOU for sharing! (Subscribed)
Old Oct 13, 2011 | 09:18 AM
  #98
ralfi's Avatar
No, it doesn´t understeer as you describe it.
We run relatively much camber at the front and less camber at the rear.
We also run a bit toe in at the front and a bit toe out in the rear axle.
With the Toyo R1-R the car has so much grip and drives superb.
Old Oct 13, 2011 | 10:49 AM
  #99
R/TErnie's Avatar
I run 3.8 degrees of camber up front & 1.8 in the rear on 285 Hoosiers.
I run a bunch of tow out up front and a little tow out in the rear & 12k/16k rates on Ohlins DFV's
The car understeers because it has 950 pounds on the front tires and ~ 600 on the rears.
You need a rear diff that locks up on accel to get the car to rotate on corner exit. I'm sure your car drives superb going straight.
Just my advice to you. I see you don't need it... so carry on.
Old Oct 13, 2011 | 11:13 AM
  #100
ralfi's Avatar
Do you know, that the wagon has a mechanical LSD in the rear?
Old Oct 13, 2011 | 12:00 PM
  #101
R/TErnie's Avatar
You'll have to be a bit more specific. Torsen Type 1 or 2, Salisbury, or Weismann?
Old Aug 20, 2012 | 12:36 AM
  #102
evo4life99's Avatar
Wicked collection !!! Yeah mon , cars lookn real good
Old Aug 20, 2012 | 07:39 AM
  #103
Josh x's Avatar
sweet rides!
Kevin Troy
Mar 23, 2013 01:10 PM
EVOheaven
May 6, 2010 04:47 PM
show time
May 1, 2007 09:44 AM
