R/TErnie's 2.2L 6262 Evo9 Build thread
I see you went with the safer route by using 159mm rods & -6mm pistons vs. the162mm rods and -9 pistons. That would be a rod stroke ratio of 1.6915 vs. 1.7234. Probably not much difference in max rpm though. Great thread! Good luck with your build.
