R/TErnie's 2.2L 6262 Evo9 Build thread
Should be fine, buddy. I really don't expect my car to be ready for a couple weeks at the earliest. Things need to be shipped/massaged/returned possibly. It is possible things would be ready when Mikey is ready to head down.
Actually, if you head down before me you could even take the clutch down there with you. We'll figure it out.
What are you doing for the front motor mount bracket? It seems the 2.4 block doesn't allow for the evo bracket to be mounted on there without drilling and cutting. Just curious what you have to say about that.
I cut mine with a band saw to shorten it and just drilled a new hole. It works great and with a coat of paint looks like it was never modified. I was curious if you had the same issue. I know not all 2.4 blocks are identical. There are some slight variations in them from different years and models. Anyway, good luck with the rest of your build.
We just attempted to use earl AN fittings last week for oil lines on the oil cooler. Epic fail, those things are garbage IMO.
All of them couldn't even hold together. We just end up using push fittings, they hold way better.
I hope you fair better with them.
