NsPyR's EVO !!! China
Old May 9, 2011 | 10:29 PM
  #181
nspyr's Avatar
Some updated pics of my rides
Old May 9, 2011 | 10:32 PM
  #182
TravEvoIsBeast's Avatar
^^Is that a X in the first pic to the left?
Old May 9, 2011 | 10:33 PM
  #183
Or should I say VI?
Old May 10, 2011 | 04:10 AM
  #184
nspyr's Avatar
Originally Posted by TravEvoIsBeast
Or should I say VI?
Actually it's a china made lancer called lioncel.... Front wheel drive 1.6ltr engine but that one has a evo 6 bodykit and a turbo kit...
Old May 11, 2011 | 08:24 PM
  #185
Wayne99gsr's Avatar
Some sweet rides in china!!!
Old May 18, 2011 | 07:47 PM
  #186
sharpshifter's Avatar
loved out the evo turned out ...sweet
Old May 19, 2011 | 01:53 AM
  #187
nspyr's Avatar
Thanks guys, i also just ordered the stage 2 transfer case and wavetrac LSD. Will update more pics soon....
Old May 19, 2011 | 06:19 AM
  #188
SmurfZilla's Avatar
Nice.
Old May 19, 2011 | 08:38 AM
  #189
nice
question you guy over there cant get the FD2-R? why not get one an boost that ?
Old May 20, 2011 | 02:26 AM
  #190
nspyr's Avatar
Originally Posted by sharpshifter
nice
Both cars are mine, in china we don't have the k20a engine civic only the r18 engine...
Old May 22, 2011 | 07:32 PM
  #191
nspyr's Avatar
Just thought i'd update with the correct updated parts list of my car;
Updates 24/10/2010 I am now getting these parts now.... Will update with pics soon...
1) BC 2.3 stroker kit (86mm)
2) BC intake & exhaust valve (+1mm)
3) Cometic gasket 1.4mm
4) Arp head
5) Arp stud
6) Oil pump
7) Water pump
8) Rebuild engine kit
9) Rc 1000cc injectors
10) Main & conrod ACL EVO 9 bearing
11) Custom Port head
12) Balance chamber
13) Remove balance cam
14) Hks oil cooler
15)Ams f1-i intake manifold
16) Boomba 75mm Throtte
17) AMS intake fuel kit
18) AMS upper and lower intercooler and pipes
19) Link G4 xtreme EMS
20) AEM water Injection
21) Sheptrans Ultimate Ratio Stage 2 gearbox
22) Sheptrans Stage 2 T-case and wavetrac LSD
23) ORC triple plate clutch
24) K20A ignition Coil system
25) Link Boost Controller Sensor
26) Polyurathane Motor Mounts
27) Forge Acuator that can withstand 2 bars (dunno if the FP black turbo's stock acuator can take 2 bars)
28) Goodridge Stainless steel braided brake lines
29) Stainless steel Clutch line
My next mods i am thinking is upgrading the rear diff, thinking of getting TRE or Shep Trans to do it, but seems TRE never replies my emails but shep trans customer service is much better !!!
also still deciding if i should change my cams from the BC272 to something more aggressive ?
Dunno how much awhp i will make with this setup and pump gas coz we dont have a 4wd dyno here !!!
Old May 23, 2011 | 07:24 AM
  #192
Geoff Raicer's Avatar
get the carbonetic differentials.. TRE is very very good, but carbonetic diff is one of a kind
Old May 23, 2011 | 08:33 AM
  #193
MOREPSiTEHBETT4's Avatar
wow, original rundance evo(not the original surely) and the gdr tomei/cusco wrx!
Old May 23, 2011 | 07:38 PM
  #194
nspyr's Avatar
I am having a problem ATM, my ex temp are high but my afr is rich... Isn't it supposed to be when your afr are rich your ex temp is low ?
On idle my arf reads 12.2 or richer, and ex temp is 300degrees.... What could be causing this?
Old May 23, 2011 | 07:56 PM
  #195
blackjoint's Avatar
were you on 8th civic? lol Im in the same boat, si got totalled; now im looking for an evo
