Archiebabes 2001 Mirage To EVO V Conversion
Old Jul 31, 2010 | 01:47 PM
  #106
ArchieBabes's Avatar
^^ Still waiting for my EVO VI TME Trunk and Wing pare.
That would complete the exterior parts that I have.
Now I need to install the front bumper.
Old Aug 1, 2010 | 09:29 AM
  #107
Originally Posted by vipers
interesting how much wheel gap the factory left.... ive never heard of any problems adding adapters to drum brakes... and i think 25mm would definently bring her out to where she needs to be
Standard EVO V wheels are 17X7.5 wide with 225/17/45 tires.
What size of wheel spacers do I need to make it look like 17X9 so that it can be flush with the front and rear fenders?
25mm? 38mm? or 50mm?
Thanks for the help.
Old Aug 1, 2010 | 09:32 AM
  #108
Okay I went ahead and googled the conversion to millimeter to inches.
38mm = 1.5inches
So that makes the 17X7.5 a 17X9 wheel size when you use the 38mm spacer?
Old Aug 1, 2010 | 11:30 AM
  #109
JACOB3RD's Avatar
how come you didn't start with your engine components first
Old Aug 1, 2010 | 12:22 PM
  #110
vipers's Avatar
38mm = 1.5inches
what you need to do is measure the distance from the front of the wheel to exactly where you want the wheel to sit.. that will be the exact size adapter you need... and make sure you say and buy an adapter.. spacers are just rings..adapters have studs pressed in them, and you bolt them to your hub, with no need for extended studs..although at 38 + mm, i dont think extended studs could be used anyways
the 38mm only works if the offset was much lower, then all 1.5" would be outward... if you have 2 wheels 17x7.5 and 17x9 with the same offsets, then the wheel will only come out 3/4" further than the 17x7.5..becuase half of it goes inward too...(im sure you knew that, this was a "just in case" response..lol)
but to answer your question, if you did want all 1.5" outward from where the wheel sits now, then a 38mm adapter is perfect
but just measure from the face of the wheel, to where you would like the wheel to sit after you put on adapters, and there you go
Old Aug 1, 2010 | 12:37 PM
  #111
vipers's Avatar
oh... and beechen build!! you actually inspired me to do research into doing one myself... thinking about selling my RX-7 and building a daily driver evo5 so i can park my 9
Old Aug 1, 2010 | 01:53 PM
  #112
Thanks Vipers I will try to measure the face of the wheels to the fenders.
Old Aug 1, 2010 | 03:44 PM
  #113
FLOW1's Avatar
Keep it up Archie.
Old Aug 1, 2010 | 04:04 PM
  #114
downshift411's Avatar
you wont be able to use evo 5 rims on that stock offset. you have to use wheel adaptors or go awd.
Old Aug 4, 2010 | 07:46 AM
  #115
TME Front Bumper Installed.
I am still waiting for my TME Front lip to arrive.
Old Aug 4, 2010 | 08:04 AM
  #116
4G63K's Avatar
Getting there!
Old Aug 4, 2010 | 08:41 AM
  #117
RockmanX's Avatar
looking good man lets get some side and rear shots now for a updated
Old Aug 4, 2010 | 09:27 AM
  #118
shrty10135's Avatar
subscribed, looking awesome!
Old Aug 4, 2010 | 10:25 AM
  #119
MaD_CaNaBiCe's Avatar
wow looking really nice I just brought and evo V last week but I siold the shell
Old Aug 4, 2010 | 10:35 AM
  #120
CrazyEights's Avatar
Very nice build so far. I'm definitely looking forward to how this turns out.
Best of luck to you!
