Boostinat30psi's re-build thread (accident related)
Old Nov 9, 2010 | 07:24 AM
  #106
BOOSTINAT30PSI's Avatar
I have no clue to be honest with you. The only thing that was different is that the turbo went from being a 9.8 hotside to a 10.5 hotside
or... Maybe since the mount was off... On the tranny side... That maybe it was leaning a little to the driver side and it has hitting the bracket!
Old Nov 9, 2010 | 07:37 AM
  #107
FLOW1's Avatar
Very nice so far, keep it up.
Old Nov 9, 2010 | 07:42 AM
  #108
Thank you very much!
Old Nov 10, 2010 | 08:28 AM
  #109
Kevmac3685's Avatar
Looking sharp brotha!
Old Nov 10, 2010 | 08:39 AM
  #110
Evolento's Avatar
Woah, what a project bro. Keep up the good work man.
Any word on the polishing ordeal?
Old Nov 10, 2010 | 10:06 AM
  #111
Thanks homie... I still havent picked up the part yet... But when i do.. You will know!
Old Nov 10, 2010 | 10:15 AM
  #112
Also this weekend will be tough... Cuz im getting my new evo in
Old Nov 16, 2010 | 12:47 PM
  #113
mkcolgan's Avatar
Any updates yet?
Old Nov 20, 2010 | 07:07 AM
  #114
Yes.. As a matter of fact. I dont know if its bad news or good news...
On wednesday i dropped off a new rad fan and the p/s oil cooler line. They said the car will be ready to start that day. Me getting excited told them to call me when they go to do it so i can leave work. I get a call from them hours later saying that the car cranks... But wont start.
So i rush over there and try to diagnose the issue. We tried all the fuses... And relays.. Nothing
then we try power to the pump.. Because i wasnt hearing it pump... Nothing
we gave up and i told the shop that i will come back tomorrow since im off.
I got there bright and early and remembered that a friend of mine told me to put a scan tool on the car. Sure enough.. It was the crank position sensor.
So i ordered one.... And im waiting for it to come in. I was told that the timing belt has to come out to get it and its best if i do a timing belt service on the car. Im officially broke.. So i cant afford to do it..
A buddy told me that he can get the sensor replaced for me so ill give it a shot. I hope thats the only issue.
Old Nov 29, 2010 | 11:08 AM
  #115
OK... WE TRIED TO INSTALL THE CRANK SENSOR.
i got a call from the mechanic. he said that there is shreads of my timing belt on the bottom of the crank pully area. he also mentioned that the timing belt skipped a a tooth or two.
the bodyshop said that they will finish their job, spray the car.. and then i can tow it out of there and then do a compression/leakdown test to see if i have bent valves. if i dont have bent valves.. do a timing belt service and keep it moving... or.......................... if i have bent valves, the heads gotta get some work done. FML!!!!!!
so i gotta do what i gotta do! if the valves are bent... im going to throw my 2.3l stroker in there and make power! then when its all done.. take this swap and fix the head and then put it in the evo shell i have!
Old Nov 29, 2010 | 11:09 AM
  #116
oh yea.. did i forget to say... FML!!!
Old Nov 29, 2010 | 05:58 PM
  #117
^^^Hang in there Bro.
You have already experienced a lot of hidden issues w/ this re-build. Keep marching fwd
Peace / Joe
Old Nov 29, 2010 | 10:33 PM
  #118
Thanks joe.. For the words of encouragement. I might sell my evo shell just to get this car on the road!
Old Nov 29, 2010 | 10:56 PM
  #119
yellowevo82's Avatar
good luck bud.. if you need help with cash sell me the seibon trunk
Old Nov 29, 2010 | 11:28 PM
  #120
Thanks man... I might be selling my 2003 shell with my carbon hood and trunk... If not.. Ill let you know.
