My winter IX RS project cleanup
Yah, I figure my MPH will go up since they are more narrow than the QTP. Thanks for the offer, but I will use them no matter what, so I'll just get mine mounted this weekend.
What are the size differences? When I was using them and switched to a full slick I lost 2 mph but had a quicker et. My M&H were quite tall and it looks like you have a similar size.
According to M&H, this tires is 25.4" tall, but according to the Miata Tire Calculator, a 235/60/15 tire is 26.1" tall.
When I ran a hoosier QTP, I ran a 26 x 9.5 x 15. The width of the M&H is only 7.5", so that 2" must be what helps with MPH, since it's much less rolling resistance.
We will see, I will do a **** load of testing this Summer
Lookin good!
It's 32.5 pounds, compared to 31 pounds even with a Hoosier QTP. So it's a tad bit heavier, but I hope they work decent. We will see!
I had a little set back though, Austin found this before we mounted the 4th tire:
I called up Summit, and I will have a replacement tire on Monday, no charge to me. Now that is customer service
Lug nuts arrived today. These are the same ones that I ran on the red car, and are VERY light. 25 grams per.
They look really good installed too, because you can see so much of the wheel stud. I really like this setup so far!
Wheel spacers came fed-ex today but I wasn't home to sign for them, so hopefully I get them tomorrow!
--mark
--mark
My front wheel spacers get here Wednesday of this week, and then I can bring my car down to STM to have an aluminum exhaust made, and then I am done for the season, I think!
I was struggling to find a good place under the dash to mount the battery, so I ended up putting it back in the trunk again. I modified my Buschur Racing small battery tray to fit in the trunk with 2 bolts. It's 2 ga. wire grounding to the chassis 8" from the battery, and then 2 ga. wire running up to the front of the car, where it splits off to the fuse block, alternator and starter. 8" from the battery positive terminal is a 100 amp breaker, so that I can quickly kill all power to the car without any tools.
I have everything mounted and run, I just need to pick up 3, 2 ga. ring terminals on Monday, and then I can finish this small project up. The weather is finally getting nice here too, so I am definitely anxious to put some street miles on this beast this year!
--mark
--mark
Got my wheel spacers today! 10 extra holes drilled in them to save weight, and they weigh in at 18 oz each:
The next dry day, my car will be at the shop getting a proper exhaust
The cable I used, long with the ring terminals were just over 4 pounds, so it wasn't too bad. I will offset it by another pound or 2 by removing the 8 ga. wire that was used for the fuel pump, that is currently run to the front.
I am not going to run a kill switch until I am required too. I have that 100A breaker mounted in the trunk there, so that I can kill power if needed.
I am taking the car on it's maiden voyage tonight to a car meet, so I will hopefully have no problems, and maybe even a story or two to tell
--mark
--mark
Hope u can make it out this year, would love to see this car in person
haha nice...first event you go to, especially if its a track like Englishtown, will probably make you have a kill switch...Any idea where you are going to mount if when you do install it? Behind where the license plate is?
