My winter IX RS project cleanup
Old Dec 5, 2010 | 02:24 PM
  #76
neonglh's Avatar
I also confirmed that the one wire I pointed to above was indeed for the RS and MR factory gauges, for the oil temperature gauge. I pulled out this piece that connected to the sending unit, since I no longer have those gauges.
Old Dec 5, 2010 | 02:35 PM
  #77
mullen's Avatar
what about the brown plug?
Old Dec 5, 2010 | 03:04 PM
  #78
neonglh's Avatar
I don't know yet, I am hoping someone can look on their car, down by the alternator, and see what it's plugged into. It has to be something that's gone already in my car.
Old Dec 5, 2010 | 03:12 PM
  #79
mullen's Avatar
well i checked on my mitsu service manual and they only list my formentioned plugs in brown...unless i missed something, possibly a/c plug?
Old Dec 6, 2010 | 08:41 AM
  #80
neonglh's Avatar
Originally Posted by mullen
so far ive only located a couple plugs that are brown,B-101 (2-BR) EGR VACUUM REGULATOR
SOLENOID VALVE, A-25 (2-BR) DUAL PRESSURE SWITCH
I think you're right. Austin @ STM thinks it is the solenoid that goes under the intake manifold, which I no longer have, so that is getting depinned
Old Dec 6, 2010 | 08:52 AM
  #81
mullen's Avatar
im almost positive thats what it is
Old Dec 6, 2010 | 08:59 AM
  #82
adam_79_2005's Avatar
I've been admiring your work, I deleted my ac so I guess every electrical that connects to as can be traced all the way back to where exactly so it can be pulled out???? Is it the fuse box or does it go further into the interior? Have u sodered any wires yet?
Old Dec 6, 2010 | 09:01 AM
  #83
mullen's Avatar
he traced it back to the ecu inside and depinned them
Old Dec 6, 2010 | 09:11 AM
  #84
tscompusa2's Avatar
Originally Posted by neonglh
This picture shows the engine bay, with ALL of the wires and relays run, and as you can see, the drivers side of the bay is very very clean looking!
--mark
That picture above is with the harness back in? MY GOD..... I want to do that to my car.. how long did that take?
Old Dec 6, 2010 | 09:16 AM
  #85
tscompusa2's Avatar
I started re-installing the harness into the car today, so that I could test out the length of the wires, and test the fitment of the fuse block and battery under the dash. I think this has a lot of promise! Most of the harness is inside the car, just laying on the floor for now, but some of it goes out of the firewall. Here are some shots:
Again, this is just testing the length of the wire, and not everything is loomed yet, but this is showing great promise. The only wires coming out from inside of the car are through this one hole on the firewall. I am pretty sure the only wire that I need to extend is the large gauge starter wire, which needs to be extended by about 8" or so.
I do have some questions though, first, this brown 2 wire connector is just inches from the alternator plug. Does anyone know what it is for?
Next, there is a single wire that goes down behind the alternator, and I think to the oil temperature sending unit. Can someone confirm this?
If that is just for the oil temp sending unit for the stock RS gauges, it is coming out, but I want to confirm that before I definitely get rid of it.
Thanks guys!
--mark
the one brown plug is just something for emission crap that you no longer have.. i just zip tie that back there and leave it go.
the other ring connector im 99% sure is a ground for the alternator and of course the other plug just plugs into the alternator.
I am shocked how nice you got your engine to look with that wire reroute that is absolutely insane..... i want to do it to mine so bad.
Old Dec 6, 2010 | 09:22 AM
  #86
mullen's Avatar
i just ordered the belt to remove my a/c but i cant decide whether i want to remove the abs...it looks so clean with all that removed....
i also think im going to sell my full size koyo and buy a half like yours to do that intake setup
Old Dec 6, 2010 | 09:45 AM
  #87
neonglh's Avatar
Yup, it's going to be amazing when it's done! It's in the 20's here temperature wise, so I am going to be buying a nice big 75,000 BTU heater for my garage, and then finish up this Evo tuck
It depends on what it is. Some go to the ECU inside of the car, some go to the fuse block. If you have the connectors not used, it is safe to say that you can remove the wire all of the way, AS LONG AS it doesn't splice into other wires. That could be a disaster if you removed a wire that is still being used.
Yeah, that one is for the alternator, the ring terminal.
And thank you, the engine bay should look SUPER good once I get the charge pipe back on there. I just want to take my time, and do it perfect
Removing the ABS is tough, but it can be done. STM sells an ABS delete kit, which is made up of all the RS factory mitsu components. The half radiator is nice too, but if I were you, I would wait to do that, until you get a nice forward facing turbo kit to go in that open space
--mark
Old Dec 6, 2010 | 09:50 AM
  #88
tscompusa2's Avatar
I want to do this to mine so bad, but im so scared to dig into it like you did. you're going to get a bunch of OH's and AH's and WOW's in person when you pop the hood man.
  #89
mullen's Avatar
ya i was looking at the stm kit but havent talked myself into deleting the abs seeing how i want to auto-x and run road courses this summer
as for the ff kit, ive been talking to toxic fab about a ff stock frame manifold and downpipe
Old Dec 6, 2010 | 09:55 AM
  #90
neonglh's Avatar
I am at work now, ready to lengthen my starter wires. Of the entire engine harness, these are the ONLY 2 wires that I need to extend to move the battery and fuse block into the interior of the car. So simple!
