My winter IX RS project cleanup
Old Dec 19, 2010 | 05:56 PM
  #106
mullen's Avatar
wow that came out amazing man! congrats on job well done
Old Dec 19, 2010 | 06:02 PM
  #107
neonglh's Avatar
Originally Posted by 06MREvo
Nice man...Glad to see you have everything pretty much done and back together! What the hell turbo is that and why is the compressor cover blue? Haha...it almost looks similar to those new ATP turbos...
Good eye man.
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
Garrett GT3071R-WG, with the 2.75" inlet. T3 flange, 5 bolt downpipe surface, and quite a bit larger than the stock turbo. I will probably run this after I finish up with the stock turbo stuff. It should provide me enough oomph to go 140+, and will spool close to stock fast.
--mark
Old Dec 19, 2010 | 06:03 PM
  #108
tscompusa2's Avatar
ya that turned out amazing.. if your trans was bead blasted your engine bay would look even better, but god damn.... amazing job for sure. did you fire it up yet to confirm all your wirings good?
Old Dec 19, 2010 | 06:05 PM
  #109
neonglh's Avatar
Thanks man!
I haven't fired it up yet. I have to give it a once over, and then I have to get the wires for the starter finished up. I need to lengthen them a little bit still, so hopefully that is done tomorrow, so I can fire it back up before Christmas.
Once I guarantee that it still runs, then I can start working on the wire harness in the car, which is probably at least another 6 - 10 pounds of wire!
Old Dec 19, 2010 | 06:13 PM
  #110
tscompusa2's Avatar
im sure it will fire right up after you're done, you seem to know exactly what you're doing!
Old Dec 19, 2010 | 06:38 PM
  #111
BuiltS13's Avatar
Awesome job! Some reason that intake bugs me lol
Old Dec 19, 2010 | 06:43 PM
  #112
neonglh's Avatar
The intake manifold, or the intake on the turbo? And why?
Old Dec 19, 2010 | 06:46 PM
  #113
EvoDan2004's Avatar
Originally Posted by neonglh
I am at work now, ready to lengthen my starter wires. Of the entire engine harness, these are the ONLY 2 wires that I need to extend to move the battery and fuse block into the interior of the car. So simple!
while your at it i would upgrade this wire to a much thicker gauge.
Old Dec 19, 2010 | 06:57 PM
  #114
neonglh's Avatar
I don't think it needs it. It only has current going through when it's starting the car, so although it's a decent draw, it's very short time span of actual use.
Old Dec 20, 2010 | 08:54 AM
  #115
neonglh's Avatar
Looking back at my to-do list, I have basically finished 4 and 5, and started working on 1 and 2:
1. Rewire the headlights to have complete, factory working high/low beams
2. Wire my fans and electric water pump to key on, instead of a switch
3. Wire my fuel pump to a toggle switch, for high and low settings
4. Misc. cleanup around the car, inside and out
5. If all goes to plan, extend wires and place the entire fuse block behind the dash
Once I finish up in the engine bay, I can run the new wires up for the headlights, and have all of that done for good!
Also, it may not be clear all of what I removed from the engine bay, so I did a quick before and after in Photoshop:
Old Dec 20, 2010 | 09:22 AM
  #116
06MREvo's Avatar
^^awesome before & after!!
Old Dec 21, 2010 | 06:33 AM
  #117
neonglh's Avatar
Last night I didn't do anything to the car, I just got a chance to clean up my garage and make some more room, but I did snap a few pics with the bumper back on. I REALLY wish that I could leave the headlights out, and just put some turn signals in the carbon fiber delete panels
Old Dec 21, 2010 | 08:15 AM
  #118
StlEvo05's Avatar
Nice clean up, I'm looking forward to more of this thread when you get around to getting the car started.
Old Jan 5, 2011 | 08:19 AM
  #119
neonglh's Avatar
Last night I got back all of the wire I needed to finish up the project. I already lengthened the 10 wires necessary for the high beams, low beams, turn signals, and hazards last night, and ran them up front. Tonight, I plan on re-installing the wiring for the starter and the IAT, and then firing up the car. If it runs, I will have a little video for you all. If it does not run, i will post up the biggest sad face I can find !!
--mark
Old Jan 5, 2011 | 10:03 AM
  #120
Boltz.'s Avatar
FCOTM Winner
Great work. You've done good stuff with the car.
