Darkn3s SEX Build ||pics||
ANYONE HAVE ANY EXTRA MOTOR MOUNT BOLT/NUT?? i snapped my front mount bolt, or if you know the size i would need would help aswell ..THANKS
for a spun rod bearing? i thought that was due to lack of lubrication only. i dont think TQ can cause that.
I spun a rod bearing on a 900 mile fresh motor because i let it run 3 quarts low on oil
Dont take your new motor on a 400-500 mile cruise without checking oil religiously!
AIT sensor just came in as well.. now i need to figure out where im going to put it.. not sure if i want to put it on my intake mani since i might end up switching it up later/soon or just on my uppipe. i will not be running meth anymore
any suggestions?
any suggestions?
UPDATE!
well i got the motor back.. here are some pics that the shop took while assembling it.. more will come of course
Close up on the ARP L19 headstuds
setting ring gaps
Weisco pistons with manley rods
Oil squirters modified
Clearance set on ACL bearings
Crank ready to be installed
setting ring gaps
