Enkei RPF1
Old Mar 1, 2016 | 05:46 PM
  #121
jb103080's Avatar
I'm trying to figure the size and offset to get so I don't need to roll fenders or use spacers with 17x9 rpf1s. Thanks in advance.
Old Oct 2, 2016 | 09:01 AM
  #122
Bmurray's Avatar
Does anyone know if you can get away with a 17mm spacer in the front for 17x9 +35 RPF1s. Running 20mms now and it barrrrrely scrapes in the front. Feel like 3mm would make the difference i need.
Old Oct 2, 2016 | 09:12 PM
  #123
evo.matt's Avatar
I don't think so. I have those exact wheels and I didn't have 20mm spacers at first, so I tried using what I had which was a 15mm and a 3mm and it still didn't work. Scratched my brembos. I heard you could shave those down if that's something you would consider but otherwise I would leave the 20mm on.
Old Jan 16, 2017 | 12:42 PM
  #124
seven10's Avatar
I currently have the 17x9 et22's but I'm looking to move to something more fender friendly. Would both the 17x9 et35 and 17x9.5 et38 require a 20mm spacer up front or what would be the minimum spacer required?
Old Jan 16, 2017 | 05:13 PM
  #125
LetsGetThisDone's Avatar
9.5 +38 will need a 20mm front spacer, and possibly a 3mm rear spacer if you notice rubbin on the rear trailing arm. Other than that, they'll fit fine.
Old Jan 16, 2017 | 05:24 PM
  #126
evo.matt's Avatar
+35 is more friendly in the rear, but it requires a 20mm spacer in the front. I added a 15mm spacer in the rear to give it a more squared setup. I think the +22 is probably the best to go with
Old Jan 17, 2017 | 10:48 AM
  #127
seven10's Avatar
I have a set that are et22 now, but with the 255 Hankook R-S3's I have now I get rubbing even though my rear fenders are rolled and cut. Seems like those tires are more similar to a 265 width, so I'm trying to figure out which wheel to get and change my offset.
Old Mar 2, 2017 | 10:34 AM
  #128
bigjulzz's Avatar
terrible picture but i have a set
Old Mar 5, 2017 | 10:24 PM
  #129
Greekplaya020's Avatar
Looks good man!
Old Mar 6, 2017 | 06:42 AM
  #130
bigjulzz's Avatar
Thank you sir... they may be up for sale soon
Old Mar 6, 2017 | 04:25 PM
  #131
Nimpoc's Avatar
Does anyone have a recommendation for a 3mm spacer / hubcentric ring combo that works well? An Amazon link would be awesome.
Old Mar 9, 2017 | 03:18 PM
  #132
WelDun1's Avatar
Originally Posted by Evokid03
As said before 17x9.5 is only +18
Bad info per ussual....
17x9.5 5x114.3 comes in +18 as well as +38
Old Mar 20, 2017 | 05:32 PM
  #133
Evolento's Avatar
Finally back on the road
Attached Thumbnails Enkei RPF1-img_1448.jpg   Enkei RPF1-img_1504.jpg   Enkei RPF1-img_1363.jpg   Enkei RPF1-img_1398.jpg
Old Mar 20, 2017 | 09:14 PM
  #134
cerevo's Avatar
where da rpf1?
rpf1 fail
Old Mar 21, 2017 | 02:53 AM
  #135
Evolento's Avatar
Originally Posted by cerevo
where da rpf1?
rpf1 fail
no, you fail
Rpf1 type rc 18x9 +18 offset
http://www.jscspeed.com/catalog/Enke...es-5402-1.html
