Herra Frush y0!
Old Feb 28, 2011 | 07:50 PM
  #46
Mitchubishievo's Avatar
LOVING THE MEAT!!! Ditto on the comment made on the bottom of page one....thanks for not putting wussy tires on wide wheels .
Old Mar 1, 2011 | 03:29 AM
  #47
F0RSAKEN's Avatar
Originally Posted by Mitchubishievo
LOVING THE MEAT!!!
I bet you are....
Old Mar 1, 2011 | 05:05 AM
  #48
revvin9k's Avatar
Originally Posted by F0RSAKEN
I bet you are....
HAHAHA Mitch....
Old Mar 4, 2011 | 03:34 PM
  #49
dbsears's Avatar
Damn this is sick! Curious about your rear camber? I'm at -1.5 in the rear with my Ohlins and easily had the range to go up to -2.0? Maybe I missed the part but what was limiting your camber?
Edit: Nevermind seen the pic where you don't have much clearance with the 2.5in springs. So your going down to 6in springs so it has more clearance. Do you think thats gonna effect your droop travel much since the Ohlins don't have much to begin with?
Old Mar 4, 2011 | 05:10 PM
  #50
R/TErnie's Avatar
I haven't adjusted the camber in the rear yet...Just left it for the time being. I want to tweak the trailing link first before changing camber/toe.
I'm by no means a suspension expert, but I don't think running shorter springs limits my droop travel. I think the spring rate limits your droop travel. I have no spring pre-load, so I'm not consuming droop travel either. It limits bump travel, but I don't think I use 70% of the coil bind length in bump anyway.
These springs are for fuddy-duddy driving. For track springs, I'll need a re-valve. Then it'll be ~750/900# springs.
Old Mar 4, 2011 | 06:52 PM
  #51
spdngdragon's Avatar
Lookin great! no mudflaps...I can hear the gravel now..
Old Mar 4, 2011 | 07:22 PM
  #52
R/TErnie's Avatar
You mean OPR.
Tarmac only. The dd neon is my rally car
Old Mar 12, 2011 | 10:59 AM
  #53
R/TErnie's Avatar
So I installed the new front 6" swift springs from GTWorx. Thank you Myles and the new lady who works there I'm now able to clear the spring perch with ease. I added some more camber up front (~-3.6 degrees) which means I need some wider fenders. I'd like to run 3 degrees all the time with the ability to go to 2.5. due to the spring height...I had to lower the car some more, while still giving me a thread or two for corner balance adjustment.
I washed the car too rear suspension is next! I should be measuring this sunday and ordering bits on Monday.
Enjoy.
Old Mar 12, 2011 | 11:37 AM
  #54
WolfsFang's Avatar
EvoDave fender mod?
Old Mar 13, 2011 | 04:02 PM
  #55
R/TErnie's Avatar
Nope. Factory fenders just rolled.
Old Mar 13, 2011 | 04:34 PM
  #56
Fast_Freddie's Avatar
Veteran: Navy
Looks great buddy!
Old Mar 13, 2011 | 09:40 PM
  #57
Blu3Evo's Avatar
could be lower
Old Mar 13, 2011 | 09:47 PM
  #58
fugiwara's Avatar
I don't see why it is necessary to run 295 width tires on an EVO. In Japan the cyber evo only runs 265 width tires, to handle better on a road course doesn't always have to run wider tires.
R/TErnie
74
Dec 22, 2014 05:30 PM
R/TErnie
For Sale - Wheels / Tires
12
Nov 18, 2011 01:16 PM
R/TErnie
Northwest Region
Oct 27, 2011 04:04 PM
R/TErnie
15
Oct 26, 2011 01:37 PM
R/TErnie
Nov 21, 2009 09:57 PM
