"JUNK BOX" Complete!! 8s???
I wish you the best of luck reaching your goals tomorrow. It looks like you've got a well sorted car. Not to mention sexy has hell. Stay safe and update us from the track. I know I'll be checking the thread throughout the day tomorrow.
My fault man, ill get the list up tonight
Thanks man I appreciate!
Service at the track is horrible, ill try to update the thread as much as possible. If not, ill have someone else i know chime in with updates!
Current Mod List:
MOTOR/ TURBO KIT
BP Built 2.0 10:5:1 Weisco HD1400s/ Manley TT I beam Alloy Upgrade rod bolts/Manley Crank
Evo 8 head/Full ported polished etc/ STM 650 cams/Supertech Dual Spring retainers/ 1mm oversized valves/ Kiggly OPR
Collin@ Toxic Fab FF Manifold/ Tial Wastegate
Precison BB Billet 67/65 Turbo
Custom Dump Tube
Custom Lower Pipe
STM 3" Upper Pipe
ETS 5" FMIC
AMS F1-I Intake Manifold
Boomba Throttle Body
Tial Q Blow off valve
STM Oil cooler
Pulley
Spark Tech Sequential Ignition System
DRIVETRAIN/SUSPENSION/TRANS:
BP Built Evo 9 trans with Evo 3rd and 4th gear.
AWD D2 Spec Coilovers
DSS Stage 5 rear axles
Shep Stage 3 T-case with Quaife LSD Etc
AMS Rear Mustache bar
Rear Diff/Trail arm bushing
Base/under the hood shifter bushings
Quarter Master Twin Disk Clutch (new 8 Leg)
Wilwood small brakes in front/ Stock Brembos in Rear
Blox Lug Nuts
STOCK REAR DIFF
FUEL SYSTEM/MANAGEMENT
Buschur Double Pumper
AEM Fuel Rail
ID2000cc Injecotors
AEM EMS V1
AEM Boost Selonoid
Fuel pressure regulator
RIMS/TIRES/INTERIOR/EXTERIOR
15" Rota Slipstreams Black/ Mickey Thompson E/T Drags Slicks
ARP Extended studs when rims/tires used. I use a 12MM spacer to clear the rear brembos
Vortex Generator
20% Windown tints
JDM Taillights
9sec9 Carbon Fiber front shutters
AEM gauges Boost/Wideband/Oil pressure/volts
Street Rims 16 X 9.5 CCW Classics/ Nitto 555R Drag radials
BP=Boostin Peformance. Built and Tuned!!
I think thats pretty much everything. Might be a few things i might have left out. I tried to break it down into sections. Hopefully it all goes with it and make sense hahaha
MOTOR/ TURBO KIT
Custom Dump Tube
Custom Lower Pipe
STM 3" Upper Pipe
ETS 5" FMIC
STM Oil cooler
Pulley
Blox Lug Nuts
STOCK REAR DIFF
AEM Fuel Rail
ID2000cc Injecotors
AEM EMS V1
AEM Boost Selonoid
Vortex Generator
20% Windown tints
JDM Taillights
Ohhh haha djaftershok. Whats it do?
Hahaha ehhh just checkout my screenname
Back to the Track today guys. Weather is nice again so I hope its going to be a good day
Goal is 8 sec pass. We are at a different track where its more consistent. Hope the car hooks up better this time and i can crank off some 1.40 60s again. Maybe even a 1.3
Ill try to update it throughout the day as much as possible. Where ill be at, the service is not the best. But i will try
Stay tued!!
Stay tued!!
Ill be patiently waiting for an update that says I DID IT BABY!!!!!! 8s!!!!!!! haha good luck man!
UPDATE!!!
Just got back from the track guys. I have a very good update! The car did not go 8s yet, but I did go faster ET and MPH. I went 9.13@157.8 MPH with a 1.49 60ft. Car is still spinning as we can tell on the logs. I tried to adjust the tire pressure and 2 step but it was tough to dial it in. The track could have been prepped better but oh well. I also went 9.2 @ 163.9 MPH!!!!
Fastest Trap to date and i wonder if that is the record on the 6765. Car was very consistent today!
Temp dropped later in the day and the car wouldnt cut a 60ft that well. Backed it up with a 9.2@158 with a 1.5 60ft. I will be back next weekend 1 more time in hops for that 8 sec pass. The car has it in her, i just need to get that perfect day with a perfect 60ft. Big thanks to Devin @ Boostin Peformance for building and tuning this beast. Car runs flawlessly!
Thanks to Quarter Master, Chicago Motor Cars, Toxic- Fab, Spark Tech ignitions. I had a great time today, cant wait till next weekend
Videos will be up tomorrow for everyone. We have them all on Video
Stay tuned!!
Fastest Trap to date and i wonder if that is the record on the 6765. Car was very consistent today! Temp dropped later in the day and the car wouldnt cut a 60ft that well. Backed it up with a 9.2@158 with a 1.5 60ft. I will be back next weekend 1 more time in hops for that 8 sec pass. The car has it in her, i just need to get that perfect day with a perfect 60ft. Big thanks to Devin @ Boostin Peformance for building and tuning this beast. Car runs flawlessly!
Stay tuned!!
