Lowering springs
Old Aug 27, 2011 | 04:11 PM
IX_MR's Avatar
Lowering springs
Are there any lowering springs that don't look like the back is lower than the front?
Old Aug 27, 2011 | 05:51 PM
auto228's Avatar
tein ! but they are kind of soft !!!
Old Aug 27, 2011 | 05:58 PM
heel2toe's Avatar
Well another great question that has been asked 1 million times...
stay away from the tein springs. For the stance that you are looking for I'd suguest a set of swift springs. The spec r springs are stiffer than the sports but both should give you the height that your looking for.
Old Aug 27, 2011 | 06:37 PM
That's the way the EVO is designed. Its really not lower in the rear, it just looks that way
Read this Bro, & you will be a wise man
https://www.evolutionm.net/forums/ev...bout-rake.html
Old Aug 27, 2011 | 07:40 PM
IX_MR's Avatar
Thanks for the help guys. I think I'll get some swift springs
Old Aug 27, 2011 | 08:04 PM
Dont be so quick to decide. I ran these springs & what a great set
Ive always been an Eibach guy
http://www.tirerack.com/suspension/S...6&autoModClar=
Old Aug 28, 2011 | 12:26 AM
4G63kevin's Avatar
I'd look into the Swift Spec R's.
Old Aug 28, 2011 | 06:46 AM
Evolento's Avatar
Hotchkis
Old Aug 28, 2011 | 09:08 AM
Craig King's Avatar
Can the average joe install new springs on the Evo in his garage? Or is that something that is worth paying a shop to do?
Old Aug 28, 2011 | 10:06 AM
wasFWDnowAWD's Avatar
@OP:
tein stech springs are garbage. too soft, and will blow out ur stock struts. ive heard swift specR's are the way to go if you have mr bilsteins. if you plan on not getting coilovers (only needed if you seriously intend on being competitive in autocross or roadracing OR really need ride height adjustability) than the MR bilsteins with swift spec r springs are from what ive researched....amazing.
youre in the wrong section for this. theres a whole section dedicated to suspension: https://www.evolutionm.net/forums/ev...-tire-rack-23/
more info on the mr bilstein and swift combo: https://www.evolutionm.net/forums/ev...ec-r-pics.html
more suspension stuff: https://www.evolutionm.net/forums/ev...ead-links.html
read and research before asking the same ol question over and over.
@craig king:
you need a spring compressor that compresses the spring before taking the whole assembly apart. otherwise its normal tools. make sure you get alignment afterwards as well.
Old Aug 28, 2011 | 10:43 AM
Spoolin4g63's Avatar
just get coilovers and save yourself the trouble of blowing your struts..
Old Aug 28, 2011 | 10:50 AM
erald01's Avatar
best combo for an evo which has been prove 10000000 times:
bilstein +swift
bilstein + works
kyb + swift
kyb+ works
there you go DONE, now just pick one
Old Aug 28, 2011 | 10:57 AM
katchup's Avatar
i have swifts, liked my hotchkis more for handle. Autox'ed them quite a few times.
And you can install them without a tool. Ive done prob 5 different times with out the tool, just take the top hat off while till on the car.
Old Aug 28, 2011 | 11:55 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Don't listen to this guy. Darwinism at work. Use a spring compressor if you want to DIY. You can rent them for peanuts at pep boys/autozone or buy one from harbor freight for $10 + shipping.
Old Aug 28, 2011 | 12:00 PM
katchup's Avatar
Haha didnt say it was the right way. But is deff doable and very easy. Never hurt myself or my car
