Newest Interior Addition: Suede Gruppe-S Bezel Bezzle
Old Jan 14, 2012 | 06:00 PM
GTijoejoe's Avatar
I think this will be my last interior modification, Gruppe-S 60mm gauge bezel wrapped in suede. Matches nicely with all of the other suede pieces, my buddy wrapped the bezel and did a flawless job, its not so easy to do a piece like this (he also did my entire interior)
The rest of my interior if your interested is posted here:https://www.evolutionm.net/forums/ev...-interior.html
I also did the red bulbs on the HVAC controls. I bought both red bulbs and LED bulbs to understand which look better... its not that LED's arn't bright, but they don't disperse the light 90 degree's out from the bulb so the clear plastic insert on the control panel doesn't allows the light to distribute evenly.... so I used the regular red bulbs which are pictured below. I believe they make Tri-LED's which have them mounted 2 on the side and one on top, these may work better.
Overall I'm pretty happy with the new addition, maybe my last suede piece will be the rear deck top... but ehhh its not so noticeable.
I haven't hooked up the gauges 100%, but they are Premium ProSport 60mm, Boost, Oil press, Oil Temp.
Old Jan 14, 2012 | 06:29 PM
Mistaken's Avatar
Looks cool!
Old Jan 14, 2012 | 06:48 PM
bnr34rb26dett's Avatar
sexy
Old Jan 14, 2012 | 06:51 PM
Pirana's Avatar
Now change the headunit for one that lites up red!
Old Jan 15, 2012 | 10:07 AM
GTijoejoe's Avatar
haha, I know now it doesn't go at all...... The one in my other car changes color, this I may have to look into.
Old Jan 16, 2012 | 02:26 PM
Teal2nnr's Avatar
^^ do you have your dash in suede as well?? I could see that being very had to get dust out of....or do you just vacuum it?? just curious....
Old Jan 16, 2012 | 02:32 PM
fwd_josh's Avatar
Where did you get the red HVAC bulbs?
Old Jan 17, 2012 | 06:05 AM
GTijoejoe's Avatar
The dash is covered in suede, check out the link ^^^ if you wanted to see more pics....I do vacuum it, and/or I use a lint brush, its actually very simple. The main reason I covered the dash was to get rid of the glare in the summer time.
I got the bulbs at: http://autolumination.com/
You can also get some here...
http://www.superbrightleds.com/cgi-b...sp=%2F1157.htm
I found that the actual non-LED bulbs are actually different brightness.. so because the are so cheap, I rec. you buy twice as many as you need to sort that out.
GTijoejoe
Mar 30, 2013 12:22 PM
GTijoejoe
Jun 5, 2012 08:30 AM
