Post All Your Custom Headlight Mods in Here! | [ALL THREADS MERGED]
Old Mar 20, 2004 | 06:39 PM
  #451
bishiboy's Avatar
Neither, I used a Dremel to cut it. I did learn that you should cut about a 1/16" into the black. If you hit the clear, it shows through.
Old Mar 20, 2004 | 06:42 PM
  #452
bishiboy's Avatar
Solar: I didn't want to have that look. I'd rather have it all orange. If I can get the clear cover from Japan for the driving light, I'll take them apart and replace that peice.
I did remove it to paint. I taped the driving light area off because it doesn't have any other reflective surfaces.
Old Mar 20, 2004 | 06:57 PM
  #453
kevo's Avatar
interesting that you use a dremel, never thought of that. I bet it make the job easier and faster then to heat it up. Is it the little circle cutter( dont know what is its actual name ) that you are using? Any comment or places I need to watch out before I start playing with my dremel?
Old Mar 20, 2004 | 07:11 PM
  #454
Mitchubishievo's Avatar
These are really close to be authentic MR heads and tails, really nice job done here. How much time did it take total?
Old Mar 20, 2004 | 07:25 PM
  #455
MYEVOVIII's Avatar
Great Job! How did you re-seal it after cutting with dremmel? Also did you cut the tails also?
Old Mar 20, 2004 | 07:26 PM
  #456
bishiboy's Avatar
Yeah, the round cutting wheel. Take your time and remove the cutter every few seconds to cool, otherwise it grabs the plastic. Be prepared to be hit with hot melted plastic, unless you wear long sleeves. Safety glasses a must. Stay away from the clear plastic, cut just inside it on the black.
I used standard black silcone to seal them back. leave the bulbs out to vent, (keep from fogging lense).
Tails took me about 5-6 hours. Heads took 4-5 hours.
I baked heads at 250 for 9 minutes, came right apart. When I resealed them, I stuck em together and put them in for 5 mins, then pushed together.
I've already washed it and no leaks or fogging
I used masking tape to hold tails together overnight to let silicone set. Rubber bands would be better.
On heads I removed, wires, adjuster cable, bulbs. Everything else ok.
Old Mar 20, 2004 | 07:28 PM
  #457
bishiboy's Avatar
DO NOT use dremel on Head lights! incase there was confusion.
Old Mar 20, 2004 | 08:00 PM
  #458
solarxclipse's Avatar
I hate to say this but after looking at the MR headlight and our USDM headlight, it seems that the clear lense are bigger than our orange lens. If you ever get that piece, it wont fit right and would need some modification to fit it. Just my .02. Good luck and good job on your headlight/tailight mod.
Attached Thumbnails Post All Your Custom Headlight Mods in Here! | [ALL THREADS MERGED]-headlights.jpg
Old Mar 20, 2004 | 08:26 PM
  #459
jotan82's Avatar
lovin your tails...
Old Mar 20, 2004 | 08:36 PM
  #460
Deceit's Avatar
god damn I want mine done so bad
Old Mar 20, 2004 | 08:40 PM
  #461
SirAragorn's Avatar
good job, looks good. I like the stock color on my silver though.
Old Mar 21, 2004 | 06:07 AM
  #462
NoTiGuY's Avatar
solar,
i think its of the same size. I guess its the way the headlights are taken (pictured) that makes it look smaller/bigger.
Old Mar 21, 2004 | 11:42 AM
  #463
I just want to clarify that MR headlight looks exactly the same as the VII headlight except it was blackout and have HID/foglight. I just happened to do a blackout housing on a VII headlight and I found out that the orange lens on the bottom was smaller than VIII's headlight. I was going to put the orange lens to the VIII but it doesnt fit right because the orange lens was too small. I think the clear lens on the MR headlight was on the headlight lens cover.
MR headlight
VII blackout headlight
Attached Thumbnails Post All Your Custom Headlight Mods in Here! | [ALL THREADS MERGED]-vii-blackout-headlightright.jpg
Old Mar 21, 2004 | 06:17 PM
  #464
HxllxMan's Avatar
When you bake the lights, it don't damage bulb and other?
Old Mar 21, 2004 | 07:46 PM
  #465
bishiboy's Avatar
Remove the bulbs and as much other stuff as you can, but as short a time it's in the oven (I used 250F for 9 minutes to dissmantle and 5 minutes to stick em back together), I had no problems.
