2003 Evo IX conversion build thread.
Old Jun 13, 2012 | 12:55 AM
Graphic's Avatar
She is officially on the charger. Should be able to start her up tomorrow. I am hoping to finalize everything. I need to spend some time reading about how to flash my ECU with the base tune that Aaron from English racing gave me. I'm a little nervous since this is my first build of this caliber. Hopefully everything goes okay!
Some shots of the interior.. I've decided to order some seat brackets as I'm behind schedule
Old Jun 13, 2012 | 02:11 AM
suekie's Avatar
It's getting there bro. Hope everything goes well on "starting" day.
Old Jun 13, 2012 | 07:26 AM
EvoTillIDie's Avatar
This is inspiration and motivation for me....because this thread is AWESOME! Good luck on start up day! Can't wait !
Old Jun 14, 2012 | 01:13 PM
Graphic's Avatar
I started the car yesterday. After fixing a few gremlins:
Starter nut/power wasn't connected (I was missing parts so I had to order some and I forgot I needed this since I had to purchase starter bolts.
Fuel pump relay was bad (thankfully I had a spare):
  • To diagnose:
    • I did a compression test 130-140 across the board on an unbroken in engine.
    • Pulled all the plugs and there was no smell of fuel.
    • Tested for spark and I had spark
    • Replaced the fuel pump relay in the engine bay since the parts were off another persons car I felt this would be a good place to check.
      • Car started up on first try.
I then got the car running but heard a nasty clanking noise from the clutch/starter/flywheel area. I feel I may have installed the clutch plates backwards. I need to pull my transmission off tonight and see what is wrong. Hopefully I'll resolve the issue tonight and get my motor broken in.
Old Jun 14, 2012 | 01:53 PM
TSTARKZ123's Avatar
Originally Posted by Graphic
Yeah I swapped Engine wiring harness, ECU, and re-pinned the transmission sensor.
Maybe I missed this step on previous IX swaps but if you used the IX harness, why the need to repin the transmission sensor?
Old Jun 14, 2012 | 02:17 PM
Graphic's Avatar
For what ever reason the sensor connector was not the same size/shape. The harness was from a 2006 GSR I believe but my transmission was from a 2003 GSR. It's quite possible it was an MR harness but the guy I bought it from said it was from a GSR.
Old Jun 15, 2012 | 01:33 PM
Graphic's Avatar
I pulled off the transmission last night and figured out what the clanking noise was. Turns out I installed the floating disks incorrectly. I plan to put the transmission and clutch back in tonight and hopefully start my car for the 2nd time. Hope there are no bugs! Crossing my fingers!!
Old Jun 16, 2012 | 01:29 AM
Graphic's Avatar
She is ALIVE! I officially started her and had her running at 1:02am!!! I'm so stoked. I could here a very small sputter on ocasion which I will have to diagnose, but seems fine. She doesn't quite idle on her own yet but I believe I need to adjust the throttle position sensor "TPS". I am super stoked!! Fixed my clutch issue, got the transmission back on, she sounds beautiful! I took some videos so I'll post them as soon as I get them uploaded.
Old Jun 20, 2012 | 04:30 PM
Graphic's Avatar
She Lives!
She lives! I'm about to post the vid here shortly
Old Jun 20, 2012 | 05:45 PM
Jush's Avatar
Great to hear!.
How goes the case against the engine seller? Anything you can say?
Hate when people get ripped off by asshats
Old Jun 20, 2012 | 11:59 PM
Graphic's Avatar
Link to video
Old Jun 21, 2012 | 08:40 AM
DecepticonsMR's Avatar
nice build! can't wait to see her finished!
Old Jun 21, 2012 | 09:35 AM
the video is private : /
Old Jun 22, 2012 | 01:15 PM
h13cofrei's Avatar
Wish I could see that video, anyways that car is beast. I can't wait for the rest^.^
Old Jun 22, 2012 | 02:16 PM
Graphic's Avatar
Oops :P one sec
Video is now open to public.
