Wideband 02 Installed
Old Jan 30, 2004 | 05:04 PM
Reignman's Avatar
Got my Wideband 02 unit installed on the Evo tonight. I placed the readout in place of the clock. What do you guys think?
Old Jan 30, 2004 | 05:06 PM
evoD's Avatar
looks great! the only problem i had previously of putting the turbo timer in the position of the stock clock was that everyone who got in my repeatedly told me my clock is off...
Old Jan 30, 2004 | 05:38 PM
blonde's Avatar
amazing bro excelent placement and great clean work
Old Jan 30, 2004 | 05:44 PM
DrEvo's Avatar
Looks great man, really, really clean!
What wide band did you decide to go with? FJO,LM-1,AEM.....
Old Jan 30, 2004 | 08:48 PM
Reignman's Avatar
Thanks guys! Its a Techedge unit which I found was much less expensive then most other units.
Old Jan 30, 2004 | 08:56 PM
nabit's Avatar
looks good man!!
Old Jan 30, 2004 | 08:59 PM
en1gma19's Avatar
Looks good man, I'm considering the AEM wideband....but it's like $500 ....how much did you get this one for if you don't mind me asking
Old Jan 30, 2004 | 09:18 PM
Boeturbolancer's Avatar
my understanding of Wide Bands is that they are extremely susceptable to water vapor and therefore should not be left in a car that isn't going to be running/tunning... Sensor supposedly crack when after morning starts??
That's definately the way to stay ahead of most others though... now just tune away! Clean install!
Old Jan 31, 2004 | 05:39 AM
gunzo's Avatar
Great idea
I run a techedge .. and I ran it with a another WBO2 once .. the readings were off by about 0.3 ( techedge running richer )
Again .. note techedge sensor was in the downpipe while the motec was at the tip
Only thing lacking .. response is ALOT slower on the techedge
Old Jan 31, 2004 | 06:16 AM
nastea's Avatar
nice how much did that specific wideband cost, i found one for like ~350
Old Jan 31, 2004 | 08:53 AM
Reignman's Avatar
The Techedge cost me around $350 for everything. I havent heard anything about leaving the sensor in might crack the sensor. The 02 sensor I got is used in cars everyday so I dont think that will be an issue.
BTW does anyone know what wire I need to run off the ECU to get the RPM signal?
Old Jan 31, 2004 | 02:46 PM
Trbo Dad's Avatar
RPM is pinout 58 (Green/White wire). Go to this site:
http://home.fuse.net/wallace/e-manage_Install.html
It is for the emanage install, but it will help you out.
Old Jan 31, 2004 | 03:56 PM
Reignman's Avatar
Thanks
Old Jan 31, 2004 | 06:20 PM
MrBonus's Avatar
Holy crap! It's 14.4 O'Clock!
j_barcarse
Jan 11, 2012 07:53 AM
YNGEVO
13
Mar 13, 2009 02:34 PM
BlackonBlack2
10
Sep 28, 2008 09:47 AM
spyderx
14
Nov 24, 2006 08:08 AM
BoostWhore
Aug 23, 2005 10:15 PM
