Evodave fender mod?
Old Jan 23, 2013 | 04:22 PM
06ebevo's Avatar
haven't found the set yet but i'm also running just the brackets, no space by the headlights for me
Old Jan 23, 2013 | 08:23 PM
Ruthless.'s Avatar
Nevet said it couldnt be done and i can appreciate you tryin to help a fellow member out, but if they dont have the means to do it or dont wanna hassle with it, they can get a niced precision aluminum kit with full instructions
Evo looks good btw! Love the yellow brembos.
Old Jan 23, 2013 | 11:26 PM
johno's Avatar
Yeah i could make my own but i don't feel like going to my dads house to make them rather just buy it.
Old Jan 24, 2013 | 09:12 AM
xtruemassacre's Avatar
can you post a pic of your "gap-less" space by the headlights?
Old Feb 6, 2013 | 04:33 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
No vending in this thread...
Old Feb 11, 2013 | 09:19 AM
nickraft14's Avatar
is there a DIY for this yet? cant find it. If not, does anyone have any laying around that i could scoop up? thanks guys
Old Feb 11, 2013 | 09:43 AM
xXANCHORMONXx's Avatar
Holy **** ok guys
You need
A maybe 4 inch strip of metal 4" long x 2" wide x 1/5 inch thick or so
Cut it in half and stack the plates.
Drill 4 holes.
Also 2 1 inch long bolts
2 nuts to go with that
And 4 washers
Now take off both front wheels and remove your fender liner.
-optional- remove the side skirt, there's a few plastic clips in the wheel well then rove 3 or 4 Phillips screws underneath the driver and passenger side door. This will allow you to push the side skirt out of the way for the next step.
Underneath the car there are 2 10mm bolts that hold the lower fender to the chassis. Unbolt them. Along with the bolt in the door jam. This is where the spacer goes. Since you have 4 holes in your spacers you can choose if you want one hole in between or 2.
You can use the oem bolt for the inner part of the spacer, then you use the new bolts for the outer part.
Now the tricky part is to push the bottom of the fender back onto the chassis and put the 2 bolts back in.
After that reassemble. Done.
Old Feb 11, 2013 | 05:07 PM
Deeeeej1973's Avatar
So simple! Thanks for the info xXANCHORMONXx
Old Feb 11, 2013 | 06:04 PM
johno's Avatar
very nice i already got the kit from ruthless once usps decides to figure out where its at lol
Old Feb 11, 2013 | 08:24 PM
No problem!
Old Feb 15, 2013 | 11:47 AM
Mr. Move's Avatar
nvm i got my answer
Old Mar 5, 2013 | 09:26 PM
johno's Avatar
picked up the kit should have it installed soon
goevox
Sep 12, 2011 01:59 AM
EVOOOOO
Nov 17, 2009 05:02 PM
bryann76yang
Feb 9, 2008 12:39 PM
evoWALO
May 18, 2004 05:31 AM
