Jdm double din dash size?
Old Nov 11, 2013 | 10:26 AM
RallyRed4g63's Avatar
Hey guys. Im looking to do the double din radio swap. I have already started the hvac relocation but i havent bought the jdm double din trim piece yet. I found it for sale on japanparts.com but im not sure how large the opening is so i dont know how big of an indash touch screen i should get. Does anyone have any ideas or insight? Thanks in advance guys
Old Nov 11, 2013 | 03:20 PM
wazmunstr's Avatar
If you buy a double din head unit of any sort it will fit, unless you are trying to do something else like an iPad mini installed or something else custom.
Old Nov 11, 2013 | 03:57 PM
Ok awesome thank you. I didnt know if it had to be a certain size
Old Nov 11, 2013 | 05:42 PM
SABSquid's Avatar
I got the same double din kit from that same site. I don't know the exact size of the opening but I can vouch for a quality product. Any double din radio touch screen thing SHOULD be fine.
Also if you don't mind, where did you pick up an HVAC relocation kit?
Old Nov 11, 2013 | 06:04 PM
I actually fabricated it myself. I found the original hvac piece and an extra cubby hole for the bottom and did a little cuttig and fabbing and voila haha
Old Nov 11, 2013 | 08:14 PM
TigOLDBiTTies's Avatar
any tablet or screen thats 7" will work. i highly recommend going with a tablet over a double din unit because of ease of installation and price. im running a kindle fire hd for $200. i am also using the japanparts surround piece and recommend the textured one over the silver mr piece.
Old Nov 12, 2013 | 03:20 AM
Yeah id prefer the textured piece over the smooth anyways
Old Nov 13, 2013 | 08:37 AM
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
i did this as well and any 7" double din will fit properly, i do have a small problem with glare, i tinted my windows to correct the problem.
Old Nov 13, 2013 | 12:06 PM
Awesome thank you. I wish i could find the orbital top piece because i love how it has the awning over the top. Did you need to buy an outer piece for the headunit to close up any gap between the headunit and the dash trim? And how would i mount a tablet? Im not sure how that all would work?
Old Nov 13, 2013 | 12:56 PM
USCGSAM's Avatar
i made a bracket to hold the radio but the gap is minimal any less and it might have a problem flipping down.. there are many threads involving "CARputers"
Old Nov 13, 2013 | 01:22 PM
Ok thanks! Ive seen just mounting the new radio into the factory hvac mounts works out well too
Old Nov 13, 2013 | 06:00 PM
Mr. PSSsSt's Avatar
FCOTM Winner
I have a 7" double din in mine
Old Nov 14, 2013 | 12:54 AM
2 small s brackets and some hot glue and my tablet has been in for over a year with zero issues.
the double din is outdated, harder to install, more expensive, horrible screen when compared to a tablet, and requires a battery source as opposed to having its own. i have zero wait time as soon as i turn my key my tablet turns on to the home screen. you should do some more research especially if your worried about glare. the new tablets are designed to work in the sun while the double din screen will be hard to see anything.
Old Nov 14, 2013 | 03:20 AM
Tigoldbitties, do you have any pics of your set up?
Old Nov 14, 2013 | 01:45 PM
i dont have any of the back side but all i did was take 1/2 inch flat steel and make 2 square S shaped brackets on the back of the tablet. previous owner screwed up the dashboard trying to remove his radio. he was an idiot.
Attached Thumbnails Jdm double din dash size?-20131114_162219.jpg   Jdm double din dash size?-20131114_162359.jpg
