What to do about minor surface oxidation underbody?
Hey everyone, i just picked up an 05 evo 8 with 30k miles and the underbody has some slight oxidation and paint peeling from being driven in one winter and then sitting for over a year. There is no rot or rust holes or anything but i just pulled the engine and tranny and im building the car and im going to just do everything while i have it all out. What is the best thing to do about it? Should i just bring it to a body shop and have everything re-done or what is the best option? Just need some help thanks.
If you are concerned about it then I would reccomend that you jack the car up as high as possible, take a pressure washer to the factory (garbage) undercoating and remove as much as possible. Let it dry overnight. Then re-apply with a higher quality undercoating.
This is what I used and the results are fantastic.
http://www.autogeek.net/wuhibuunun.html
Overall it took 2.5 days for me to clean and re-seal the underbody. Note that my car was previously used for rallycross and at least 12 hours was spent removing the massive accumulation of mud that was caked in everything.
