H11 foglamps bulb
Old Feb 29, 2004 | 05:45 PM
chase's Avatar
H11 foglamps bulb
For those of you who wants the ion bulb for your evo foglights...here the link http://www.europeanautosport.com/optik.htm
http://www.europeanautosport.com/yellow.htm
Old Feb 29, 2004 | 07:20 PM
Toobs's Avatar
Thanks for the info, I might try the Ion H11.
Old Mar 1, 2004 | 09:56 PM
Corey's Avatar
I know there were some guys on here that upgraded their HID's. I'm just wondering if the beam went any further or did it just change the color?
Old Mar 1, 2004 | 10:43 PM
ku7484's Avatar
i put them in... and they did make a difference in change.. It doesn't quit match the headlights... but its hardly noticeable.. from a distance it looks the same, and its alot brigther. About a 30volt difference. Its well worth 30-40$. Gives off a bright white instead of a ugly yellow the stock ones gave out.
Old Mar 1, 2004 | 11:16 PM
AWDTurbo4's Avatar
very nice! to change fog or headlight bulbs, do i need to remove front bumper?
Old Mar 1, 2004 | 11:45 PM
ku7484's Avatar
not at all... all you do pop the hood, twist the wiring harness that the foglight is attatched too on the back of the headlights. Twist, it should slide out.... (might have to jiggle a little, but be SUPER CAREFUL). The thing that is holding the bulb, on one side there is a little slit that you can slide down. Slide that down and you can pull out the bulb. Replace the bulb, and set back in. YOU"RE GOOD TO ROLL
Old Mar 1, 2004 | 11:46 PM
ku7484's Avatar
the left side (facing the car) is a bit harder than the right.
Its not hard at all.. about a 5-10 minute job.
No tools needed, just your hands and common sense
Old Mar 1, 2004 | 11:53 PM
AWDTurbo4's Avatar
thanks "ku7484" Im gonna order a set tomorrow,
I like that hid look but I would also like to see a better pic of the Ion ones, the pic on that link is too small.
Old Mar 9, 2004 | 08:23 AM
howiEVO8's Avatar
ummm...i thought most cars are only 12 volt.................
Old Mar 9, 2004 | 07:42 PM
Evo Spec VIII's Avatar
yea they do, he must mean watts.
Old Mar 9, 2004 | 11:17 PM
AWDTurbo4's Avatar
got mine today they look 10 min. both sides and done!
Old Aug 5, 2004 | 12:28 AM
titaniumkingpin's Avatar
i have a 03 us evo and want my foglights to match the headlight color as close as possilbe. which one would i be interested in?
Old Aug 5, 2004 | 10:32 AM
value's Avatar
Foglights no, HID bulbs yes. Using PIAA H11 4700K bulbs. Nice and bright.
Old Aug 5, 2004 | 10:37 AM
Guack007's Avatar
Thnx for the info
Old Aug 5, 2004 | 05:50 PM
EVIL VIII's Avatar
I purchased 80watt replacement H11's from www.supremepowerparts.com...and they are awesome! Look very close to HID's for replacement bulbs...passenger side is a bit more difficult due to hosing in that area, but overall easy install and great lighting upgrade!!!
