Wide Fenders
Wide Fenders
I want to get wider wheels. I've heard of people rolling their fenders? What about getting aftermarket fenders that fit the oem body. Like this one
http://www.lancershop.com/customer/p...cat=251&page=1
Any other ideas? Right now I have 245. I want to get as wide as possible. Going for the aggressive sticking out the car look. Thanks guys!
Rolling the fenders will only help with wheels/tires that are within the wheel well. Most Evo owners will loosen the bolts and "pull" the fender in order to get more clearance. You can also add shims in some places and "pull" them to get extra clearance.
When you roll the fenders you are just rolling the lip that protrudes into the wheel well pushing it up more so it won't rub on the tires when the suspension is loaded and the wheel is up in the well.
If you want to see setups and know what people are running check out the aggressive wheel thread in this section.
you may also look into the "evo dave fender mod". it is a bracket that pushes the stock fender out for more clearance, and depending on taste (i happen to like the look) it may be another option than risking rolling the fenders and gaining minimal clearance and risk cracking the paint. as stated though running wider front fenders may make it look unproportional. there are quite a few options when going to wider fenders though, such as voltex, garagehrs, do-luck, and apr i think.
NocturnalEVO
Jan 6, 2017 12:55 PM
